Semaphores don't always lift
NAES
NAES is offline
PostPosted: Thu Dec 29, 2022 8:02 pm    Post subject: Semaphores don't always lift Reply with quote
Hey all. I'm having a little trouble with my semaphores lifting consistently. Sometimes they'll pop right up, other times they look lile a kid trying to bench 225 for the first time, kinda a struggle. Lol. Revving the engine to give full voltage foesn't seem to help. They're free and not hitting anything on the way up. Running 12v and they're wired correctly. Once they're up they're locked in nicely. Any suggestions on what to try?
Thanks, NAES.
Barndoor Mafia
Box On Wheels
SBS #00
esde
esde is offline
PostPosted: Thu Dec 29, 2022 8:47 pm    Post subject: Re: Semaphores don't always lift Reply with quote
check all the connections, including the grounds.
modok wrote:
NAES
NAES is offline
PostPosted: Tue Jan 24, 2023 10:44 pm    Post subject: Re: Semaphores don't always lift Reply with quote
Well cleaning all the contacts didn't do much. I did spray electrical cleaner in the solenoid and piston assembly and that helped a bit. I also adjusted the semaphores so they 100% clear the body opening. If I rev the engine and get full 12V power to them they work almost every time. Once they're locked out they stay up just fine.
I guess its just one of those little quirks I'm going to have with my rig. No big deal, I have much bigger things to work on!
NAES
Barndoor Mafia
Box On Wheels
SBS #00
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sat Jan 28, 2023 10:40 am    Post subject: Re: Semaphores don't always lift Reply with quote
Voltage dropping..
You could always ad individual relays to each side.
Basically use the signal to as control and have full battery circuits to the load.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
scottyrocks
scottyrocks is offline
PostPosted: Sat Jan 28, 2023 12:37 pm    Post subject: Re: Semaphores don't always lift Reply with quote
This is why the original trafficators were not actually mechanical.
Here is an early version signalling to take the third reich.
Well now that kind of ruined the joke.
Oh well. haha
– D. Tartt, 'The Goldfinch'
AirHead1966
AirHead1966 is offline
PostPosted: Sat Jan 28, 2023 12:45 pm    Post subject: Re: Semaphores don't always lift Reply with quote
Is that called erectile dysfunction?
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Sun Jan 29, 2023 6:30 pm    Post subject: Re: Semaphores don't always lift Reply with quote
For the best erection use a relay with 10 AWG wire and a fuse from the battery.
Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
