4118thing Samba Member
Posted: Sat Dec 31, 2022 3:34 pm Post subject: Master brake cylinder pressure switch |
Is there a washer that mounts on the pressure switch when screwing into the master cylinder? Or Teflon, or other tape, used? |
SGKent Samba Member
Posted: Sat Dec 31, 2022 4:32 pm Post subject: Re: Master brake cylinder pressure switch |
I don't know. Maybe someone else will. Here is an image from jersey looker. Yo have to click on it to see it.
Below that is an image of an empi switch from Amazon. It shows threadlock on it.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sat Dec 31, 2022 9:34 pm Post subject: Re: Master brake cylinder pressure switch |
No, they seem to seal like pipe thread _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sat Dec 31, 2022 10:33 pm Post subject: Re: Master brake cylinder pressure switch |
I've never seen a washer used with brake light switches on VW's. The original switches had a tapered threads and sealed like tapered pipe thread, even though the M/C's have straight threading. The Bentley manuals for late Type 1's and Type 2's do erroneously mention sealing washers, but no such thing appears in drawings or parts lists. Apparently some Porsche models used switches with straight threads and sealing washers (you can get such 2-terminal switches at places like www.pelicanparts.com ). I've variously installed the switches dry, lubed with brake fluid, or lubed with Permatex #2, and never had a leak in any case. But then I abandoned those pressure switches and converted to a mechanical switch a long time ago because it was impossible to find pressure switches that weren't complete junk. _________________ '67 bug: seized by the authorities
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Tue Jan 03, 2023 8:58 am Post subject: Re: Master brake cylinder pressure switch |
Here are the electrical circuits for the three-terminal, hydraulic brake-light switches, with early & late type, hydraulic brake-circuit failure, dashboard warning lights.
Early Type
a = black-cable connection to ignition-controlled supply terminal 15.
b = black/red-cable connection to rear brake lights
Late Type
A = electric switch inside brake-circuit-failure warning-light unit
B = 3-terminal brake-light switch
C = Dual-circuit brake warning lamp
a = blue cable to brake-circuit-failure warning-light unit's
internal switch-terminal 61 (shared with ignition warning light)
b = black cable to fuse-box terminal 15
c = brown cable to Earth (i.e. Ground in USA parlance)
d = black/red cable to brake lights _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
metahacker Samba Member
Posted: Tue Jan 03, 2023 11:15 am Post subject: Re: Master brake cylinder pressure switch |
They shouldn't require anything. They have tapered threads and usually come with some dried goo pre-applied.
Hand tighten them then turn them a bit more using actual wrench force. General best practice on NPT plumbing is considered somewhere not far from 1-2 wrench turns. You will need to be the judge, but the idea is to not roach the material.
You may, theoretically, use Loctite 567 if you feel compelled. I have never needed to do that.
Also, when it comes to these switches, I'd also recommend buying the best quality ones you can.
Your life can literally depend on them.
Many "typical" switches can leak, or explode when you hit the brakes and disable that circuit of your brake system, they can also have extremely unreliable actuation - e.g. no brake lights, or massive latency on the lights.
I experienced the latter recently with a Bus I had bought that had 2 brand new switches on it of "typical" replacement quality. The brakes lights didn't respond reliably at all. I would not recommend engaging in the AutoZone or BusDepot crap-shoot on this part.
If you buy the Porsche OEM branded part of the same PN, it's a genuine original German switch with a VAG logo on it (e.g. VW circle + Audi rings)... at least it was for me when I bought them very recently.
I'm not sure which variety you need, but there is a 3 pin in Porsche OEM bagging here:
https://www.pelicanparts.com/search/?q=113945515G&redir=yes&host=search
I recently installed 2 of those Porsche ones and they are exquisite in every way; as it came from the factory.
If one is hard pressed for the $34 price difference between them, the ATE is worth consideration. I suspect it's likely no longer made in Germany, though... but can't say for sure; maybe it's the same thing without the Porsche bag. |
malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Sun Jan 29, 2023 8:25 pm Post subject: Re: Master brake cylinder pressure switch |
Found this one today. Figured I would ad one more here for future needs.
_________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Thu Feb 02, 2023 11:51 am Post subject: Re: Master brake cylinder pressure switch |
malcolm2 wrote: |
Several years ago, it was rumoured that a press-to-test style brake-circuit warning light, was available with a different coloured lens (i.e. yellow rather than red) which I had hoped to adapt as a detonation (i.e. pinking, pinging, knock or spark-knock) warning light!?! _________________ Regards.
Nigel A. Skeet
