Baja Knocking in right rear while driving
VolcomKing
VolcomKing is offline
PostPosted: Mon Jan 02, 2023 4:42 pm    Post subject: Baja Knocking in right rear while driving Reply with quote
Any advice on what could be causing the knocking sound coming from the right rear of my baja when I hit even the slightest bump? I have already tried a few things based on input from others. But I cant seem to get this figured out. Any help greatly appreciated
I have already lowered the car 1 spline to give more clearance to the stop under the spring plate (figured I may have been maxed out so it was hitting)
I also swapped the KYB shocks for EMPI Coil Overs (I know not real Coil Overs) thinking they might be bottoming out
And last I removed the engine and replaced all the trans mounts thinking it may have been twisting and causing a knock somehow.
I am at a loss and could really use the help.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Mon Jan 02, 2023 5:00 pm    Post subject: Re: Baja Knocking in right rear while driving Reply with quote
Have a look at the body mount bushings in the fender well, above the shock tower.
It may look fine. But can be crushed at the area you cannot see.
My 67 made a funny/annoying clunk. This occurred even when crossing over paint stripes on the roadway.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Wulfthang
Wulfthang is offline
PostPosted: Mon Jan 02, 2023 7:17 pm    Post subject: Re: Baja Knocking in right rear while driving Reply with quote
I had a similar thing happening on my Trail Rail. It seemed to be a kind of sharp knocking sound or clacking and it drive me crazy for a while. It turned out to be a loose bearing in the pocket on the rear trailing arm. I center punched the socket full of dimples, smeared in a thin layer of JB Weld and used a bolt to press/pull in a new West German bearing. It's been fine for quite a while now.
sailtexas186548
sailtexas186548 is offline
PostPosted: Mon Jan 02, 2023 7:47 pm    Post subject: Re: Baja Knocking in right rear while driving Reply with quote
Check the axle nuts, but more likely is a loose shock bolt, as in the hole is too big/worn in the trailing arm or shock mount, or the bolt is too small and loose there or even in the shock. I have a worn out lower right shock bushing and it does the same thing
it's more fun loud and dirty
Mikedrevguy
Mikedrevguy is offline
PostPosted: Tue Jan 03, 2023 7:12 pm    Post subject: Re: Baja Knocking in right rear while driving Reply with quote
I once went through similar sound. Replaced CV joints blah blah.
Turns out the rear shocks were rocking in the lower shock mount.
Sometimes it’s the simplest of things.
74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
earthquake
earthquake is offline
PostPosted: Tue Jan 03, 2023 10:41 pm    Post subject: Re: Baja Knocking in right rear while driving Reply with quote
+1 on this, I had the same problem, I stuck in a stack of washer and it was gone.
Eq
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
