petergariepy Samba Member
Posted: Tue Jan 03, 2023 8:47 am Post subject: 1974 Thing... considering buying.... what should I look for? |
I've stumbled upon a low miles 1974 thing that is for sale.
Stock
Original
Low miles
Minor rust.
Yellow - original and presentable
Good top
ok interior
good title/registration
What should I look for?
VIN is c1030e010 - is an early production number? (not that it matters really) _________________ Peter Gariepy
Webmaster
Click to view image |
Posted: Tue Jan 03, 2023 9:39 am Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
Webmaster
Hot Rod Harp Samba Member
Joined: March 02, 2008 Posts: 186 Location: Englewood, New Jersey
Posted: Tue Jan 03, 2023 11:55 am Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
That is not the VIN #...It would be something like the following
184xxxxxxx
The 4 denotes the year 1974. The VIN should be on a metal plate
under the front trunk, or on the sticker on the driver's vertical panel
between the doors, and on the chassis near the panel hiding the
shift coupler. Hope this helps. _________________ 74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
RinTinTin in Waldorf Astoria 1956 |
CraigInPA Samba Member
Joined: March 09, 2011 Posts: 212 Location: Norristown, PA
Posted: Tue Jan 03, 2023 12:22 pm Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
Spare tire? Windows?
Looks like the wrong exhaust. What engine is in it?
Have you tried the windscreen wipers?
How does it look underneath, rust wise? |
PatJr Samba Member
Posted: Tue Jan 03, 2023 12:34 pm Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
wow, that "thing" is in good shape
I'm not a Thing guy but I know they do have a good following.
motor, miles, .... are you really going to keep it bone stock?
the huge issue is RUST, crawl all over it, under over, look in every nook and cranny
and no accidents
imho _________________ #############################################
1970 Transporter a orange one
Posted: Tue Jan 03, 2023 1:06 pm Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
Spare tire? NONE
Windows? Including. Original in original bag. A little smoked.
Looks like the wrong exhaust. What engine is in it? Correct engine, wrong exhaust.
Keep it stock: yes
Have you tried the windscreen wipers? NO
How does it look underneath, rust wise? Surface rust overall. Some rust thru base of the drivers side rear door but mostly isolated. _________________ Peter Gariepy
Webmaster
Click to view image
Last edited by petergariepy on Tue Jan 03, 2023 1:33 pm; edited 2 times in total |
Posted: Tue Jan 03, 2023 1:08 pm Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
PatJr wrote: |
and no accidents
imho |
Some rust through below drivers side rear door. But not bad.
Miles: 22,000! _________________ Peter Gariepy
Webmaster
Joe 20 Samba Member
Posted: Tue Jan 03, 2023 8:36 pm Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
Have you looked at the sticky "what to look for when buying a Thing?" It is just above your post... _________________ "Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy |
carsdlt Samba Member
Joined: May 02, 2012 Posts: 317 Location: So. OC, Calif.
Posted: Wed Jan 04, 2023 10:10 pm Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
X2 what Joe said. A pic of the engine bay would help. _________________ Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own." |
yel-mel Samba Member
Joined: May 07, 2015 Posts: 421 Location: Tampa Florida
Posted: Wed Jan 04, 2023 10:46 pm Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
Key missing question
How much $ ? |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 483 Location: Grove City, OH
Posted: Thu Jan 05, 2023 7:04 am Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
How much $ ? |
Not much $. Just pull the ignition lock and have a new key made from the code stamped on the side. There are a couple of different people on here that can cut a key from code. Just search the classifieds for their contact info.
Is the title missing too? If so, I'd probably just walk away from the deal. _________________ '74 Thing
'83 Westfalia |
77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Thu Jan 05, 2023 1:29 pm Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
HaHa _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
Posted: Wed Jan 11, 2023 9:39 am Post subject: Re: 1974 Thing... considering buying.... what should I look for? |
Since the speedometer will not read above 99,999 miles, if your is reading 20,000 miles it is very likely to be 120,000 miles or even 220,000 miles. A seller through ignorance or grift will always tell you its a low mileage car. |
