Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Sat Jan 14, 2023 10:28 am Post subject: Re: Jeff's Bus Stocker Plus |
Brian_e wrote: |
Those damn $&@%ing delivery people. 😡 Those are the people that can break an anvil in a sandbox. I send 36lbs disk brake kits in flat rate boxes all the time with nothing lost, and they manage to screwup a light padded envelope. 🤦🏼♂️
I just installed my last set of guides yesterday. I have more on the next stock order, but it will be another week or two. 😔
Sorry man. I will get you some replacements.
Brian |
Heyman,
Not your fault at all.
It’s hard to run a business for all kinds of reasons.
And here you’re giving stuff away(!)
I’m just glad you know where to get good guides.
Any i just go and order from somewhere are almost certain to have issues.
Dollars to donuts they would have no shoulder and/or be prone to moving around.
Both myself and Jeff had valve guides playing ping-pong in our last previous motors.
Seems to me this is one of our biggest challenges right now.
Here i was thinking a new set of China heads would be OK.
Thanks to your real experience we know better!
_________________ Bus Motor Build
What’s That Noise?!? |
Posted: Sun Jan 15, 2023 7:36 am Post subject: Re: Jeff's Bus Stocker Plus |
This just in…
Big thanks to our man ‘txoval’ for another generous donation!
All we need is Jeff to get that case cleaned up,
And we can start some mock-up.
Clean, Jeff, clean!!
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Jan 16, 2023 7:52 am Post subject: Re: Jeff's Bus Stocker Plus |
I have a CB welded 37mm wide fan too if that would help |
Posted: Thu Jan 19, 2023 9:22 am Post subject: Re: Jeff's Bus Stocker Plus |
txoval wrote: |
Oo..!
Jeff you got one yet?
The PO on his bus did that great trick,
You know the one,
"Install doghouse fan shroud but leave skinny fan".
Welded isn't always needed, but i have seen old fans get loose and rattly even on stock motors.
Plus, balanced is always better...
That means you're committed to using your Andrig fan, right?
Not so sure we want to put you in that position..! _________________ Bus Motor Build
Posted: Thu Jan 19, 2023 9:28 am Post subject: Re: Jeff's Bus Stocker Plus |
This also in..
Packed like precious china..
A pair of dirty dawgs!
Complete,
Throttle shafts feel decent,
Vacuum port,
What a score!
Big big thanks my man.
We already got a Scat linkage ordered,
Plus we'll do the cleaner mount raise trick.
These puppies are going to be given every chance.
Jeff and his ultrasonic will be busy for the next couple of days,
Plus, we'll load some soda in the cabinet.
Oh, it's gonna be a party.. _________________ Bus Motor Build
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Thu Jan 19, 2023 9:48 am Post subject: Re: Jeff's Bus Stocker Plus |
isnt the VW community awesome... just amazing _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
txoval Samba Member
Posted: Thu Jan 19, 2023 10:37 am Post subject: Re: Jeff's Bus Stocker Plus |
In a bus I’d imagine he’ll be running at high (relatively speaking) rpms a lot with reduction boxes…the welded fan is good insurance.
No problem sending it… |
Seasurfnbird Samba Member
Joined: August 11, 2020 Posts: 28 Location: Pescadero, CA
Posted: Thu Jan 19, 2023 10:54 am Post subject: Re: Jeff's Bus Stocker Plus |
Clatter wrote: |
txoval wrote: |
Oo..!
You know the one,
Not so sure we want to put you in that position..! |
Oh that would be amazing! Thank you txoval! As Steve said, we found a skinny fan in the fan housing haha _________________ 67' Squareback
66’ EZ Camper
Jeff’s Bus Stocker Plus |
Posted: Thu Jan 19, 2023 11:06 am Post subject: Re: Jeff's Bus Stocker Plus |
txoval wrote: |
VWporscheGT3 wrote: |
isnt the VW community awesome... just amazing |
txoval Samba Member
Posted: Thu Jan 19, 2023 12:31 pm Post subject: Re: Jeff's Bus Stocker Plus |
I tore my ACL playing soccer on Sunday...so give me until next week and I'll send it.
Same address?
Posted: Fri Jan 20, 2023 12:19 pm Post subject: Re: Jeff's Bus Stocker Plus |
Man, I'm stoked about how this is coming along..!
That welded/balanced fan would be such a swEEt touch for this one..
Jeff came by yesterday..
We got his Grant rings checked out.
.017 or so end-gap out of the box.
Not super ideal, but better than the .022 max listed in the bible for new (smaller cast 85.5) rings.
Cylinder-to-skirt is right around .0036 - .004 depending upon where you measure it.
We gave his cylinders a 240/600 plateau dingle-ball job so the bit bigger numbers are to be expected.
A hot-running Bus, and these numbers are OK.
Besides, what can you do about them now?
We also cleaned up his factory 1.1 rockers and got the solid shafts/swivel feet ready to go for when the heads get back.
He's also getting the case vapor-blasted, at least the front section that shows when you open the decklid..
Jeff just sent me this pic - Scat linkage is in.
Anybody know where to get a pulse valve for the vacuum advance?
Now that aircooled.net is on hiatus,
I have NO idea where to get one of those.
It made such a difference on my Beetle motor with Kadrons..
Jeff has the K Dogs at his house,
And he has an ultrasonic.
Now all he needs is to get to work!
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1058 Location: St. Louis
Posted: Sat Jan 21, 2023 9:54 am Post subject: Re: Jeff's Bus Stocker Plus |
Nice! Thanks for the tip.
Jeff got two of 'em (he has a Squareback that can use the other).
He also got to work.
He's mostly-disassembling them one at a time, for ultrasonicing.
So's not to mix anything up or lose track of how things go.
He was taught to use carb dip in his ultrasonic.
Now that carb dip is EPA-compliant and sucks, I guess that's a good use for it.
Nextime he's down we'll soda-blast the bigger parts and go thru everything.
Unfortunately, I've been thru Kadrons so many times i can do it blindfolded now.
Making our shopping list for Kaddie Shack; goal is to do it all in one shot.
We'll do the air filter mount raise spacer deal, and probably new cleaners, plus kits and maybe jets.
The manifolds will get matched to heads, the balance tubes plugged, and the Alstrup divider wall lowering and bowl open up tricks.
Jeff's crappy case had two coats of old paint (partly) on it.
It was terrible looking, and i can't help but think paint insulates cases from shedding heat.
Been blasting cases lately with good results, but only provided the galley plugs are all out,
and some real diligence is employed in their cleaning afterwards.
A local MC shop does vapor blasting, and quoted Jeff $300 to do the job completely.
They will, however, do a $100 job if you ask them to.
We tried to have them hit the parts of the case that actually show,
But,
Here's what you get for $100.
Looks way better than it did.
$300 is more than this case is worth...
Man, cases are a real issue these days for those of us who aren't independently wealthy.
I remember finding a pile of single relief cases needing their first line bore in a field for free.. _________________ Bus Motor Build
txoval Samba Member
Posted: Sat Jan 21, 2023 11:15 am Post subject: Re: Jeff's Bus Stocker Plus |
I’d hit it with a light coat of cast alum or cast iron paint…I’ve never seen a drawback to it, but understand it is a debated item |
Posted: Sat Jan 21, 2023 6:21 pm Post subject: Re: Jeff's Bus Stocker Plus |
Spent some time looking at cases..
Using drill bits as gauge pins to check oil gallery sizes,
There are indeed differences between single and dual relief.
The actual bearing feed holes are the same size,
However,
There are differences in the main feed galleries,
Just like Torben says.
These bits all fit into a late case, but not early:
Here a later case has a similar size small feed hole for the cooler,
But unlike an earlier case, the outlet is larger:
Dag,
It's not a huge difference.
The oil pickup tube is going to stay small.
The bearing feed passages are the same size.
If you look closely at the long main passage where the full-flow returns to the case,
The dual-relief case seems to have the casting thicker around that gallery.
Still,
The factory didn't usually just change things for the fun of it.
Their changes to things like this were typically an improvement.
Not a big deal to go get some bits and take these over,
but,
Man!
The risk of ruining the case looms large!
And,
Are we _sure_ there's real gains for a mild 1776?
Hard for me to pull the trigger on this one, gentlemen.
Maybe if it was my case.. _________________ Bus Motor Build
txoval Samba Member
Posted: Sun Jan 22, 2023 7:25 am Post subject: Re: Jeff's Bus Stocker Plus |
Wish I had one to send you… |
Posted: Sun Jan 22, 2023 9:38 am Post subject: Re: Jeff's Bus Stocker Plus |
txoval wrote: |
Me too!
But sending a cam and fan is already WAY above and beyond… _________________ Bus Motor Build
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Mon Jan 23, 2023 10:47 am Post subject: Re: Jeff's Bus Stocker Plus |
Alstrup wrote: |
Definitely enlarge the galley!!!!!!!! |
Jeff and i were working together for about ten hours yesterday - either cleaning stuff or having a frustrating mock up.
Getting tired and hungry..
Jeff checks the thread here to see if there's any news.
"Eight exclamation points!" he says to me!
"I guess we better get some drill bits".
So i ordered my first-ever metric drill bits this morning.
one 9mm in 250mm length
one 10mm in 250mm length
one 11mm in 400mm length.
From here -->
https://www.ebay.com/itm/303904945392?var=603087820308
Oh,
I'm just picturing in my head one of those bits breaking thru the side..
Or just breaking off - way way deep in a passage...
Because, no, I'm not spending a grip o' money on good drill bits I'll use once.
I'm already planning in my head how this will go.
Lots of drill speed, go slow, don't push it, lots of lube...
OOOoooooommmmmmmmm.......... _________________ Bus Motor Build
Posted: Mon Jan 23, 2023 11:42 am Post subject: Re: Jeff's Bus Stocker Plus |
So Jeff was here all day yesterday doing not-fun stuff...
Loaded up soda in my blasting cabinet, but it sits outside and it's been wet.
Have to bang the thing while trying to blast otherwise it doesn't feed.
No light or fan inside either (it's on my list ).
A long frustrating session but he did a great job.
It was cold and wet and windy.
One thing i learned as a young teenage apprentice mechanic is how to heckle.
When a newb gets frustrated the old-timer has to needle.
Things like:
"Aawww.. she's getting upset.."
"Want a cookie?"
"You should buy one of those 11-thousand-dollar blasting cabinets with the vibratory feed"
"Want me to just do it?"
It's also always important to use the word "Buttercup" as much as possible.
The process of cleaning out a case that's been wet-blasted is a fun one.
First dry air blow-out,
then carb cleaner and more blow-out.
Gunk and high-pressure water, more air, more carb cleaner, more air.
We're clean enough for some mock up, and it was dark outside by then.
Final clean will be the dishwasher once all mock-ups are done.
PO used silicone everywhere.
Best of all, they decided to pack the pushrod tube/lifter area with tons of it.
By the time it was all scraped out, we decided to smooth up the seal area with a tiny wire wheel.
Mock-up all tired and cold and smelly was no fun because the crank decided to bind in the bearings.
It spun free before. Not sure how cleaning a case suddenly causes it to change shape.
That, and every head stud was -removed by pliers on the threads- by the PO! :snipersmile:
After smoothing down the bearing dowels that were somehow all chewed up.
It started to spin better.
The bearings are likely -slightly- out of shape now,
but I'm 100% sure they'll round right back out once that motor hits 5500RPM.
Anyhow,
One bright bit was the fact that the deck measured right at .030.
This means it won't have to go back to Jim for another decking and he won't hate me for making him do re-work!
So, we're finally getting close to actually bolting something together.
And,
If I'm not mistaken,
We're done cleaning stuff! _________________ Bus Motor Build
