yugo42 Samba Member
Joined: July 25, 2007 Posts: 61 Location: Rochester, NY
Posted: Sat Jan 07, 2023 7:51 am Post subject: Bracing needed for bay bus floor/rocker removal? |
Hi! I’m in the process of taking out my cargo floors to enable some structural repairs. I need to do rocker supports, outrigger/Jack points, and the front top hat (with lots more around the rest of the bus!).
If I cut the rocker supports out in this state, is it recommended to brace the middle of the bus to avoid twist? I’ve seen several videos of splittys torn down to that point with no bracing, but never really bays. I would do it as a precaution but am afraid of ruining my access too.
What’s the prevailing wisdom on this? Thanks in advance!
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17971 Location: Eugene, OR
Posted: Sat Jan 07, 2023 12:24 pm Post subject: Re: Bracing needed for bay bus floor/rocker removal? |
We cut up and repair our rusty squarebacks with NO bracing.
Just do it 1 section at a time. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
yugo42 Samba Member
Posted: Sun Jan 08, 2023 4:34 pm Post subject: Re: Bracing needed for bay bus floor/rocker removal? |
Thanks Mike! I looked back at the Haynes Transporter restoration manual and he doesn’t use any bracing either. I should be good to go! |
