rjrdomer Samba Member
Posted: Sun Jan 08, 2023 1:40 pm Post subject: 1957 Sedan - Hardly any brakes - master cylinder? |
Seeking some advice…I have a 1957 Beetle Sedan (US spec). A few months ago, I replaced the pedal cluster with a newly rebuilt one. Everything was seemingly fine until last week - the brakes seem to be almost gone. Push pedal to floor, don’t feel resistance until very close to the firewall and there isn’t much stopping power.
I see no apparent fluid leaks - drums/hoses/connections all dry. So I adjusted the brake shoes, only one seemed to need it. Still having same issue. Press pedal, car barely stops.
I don’t think it’s anything with the pedal assembly - it worked fine for a few months - 100 miles or so. So I’m assuming it’s the master cylinder.
Any thoughts? Is changing the master cylinder a difficult job? Do the pedals have to come back out? I hope not as that was a very tedious job. _________________ 1957 Oval Window - original pan, body, and engine |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sun Jan 08, 2023 3:20 pm Post subject: Re: 1957 Sedan - Hardly any brakes - master cylinder? |
First thing that came to mind was the free play at the brake pedal. The pushrod needs to be away from the cylinder by 1mm at rest. If the pushrod is touching and most likely applying any pressure to the cylinder, it will not allow the operation of the brakes to act normally.
If you have the correct free play. Sounds like a leak, either internally or externally. If you do not see fluid anywhere (check the bottom of the nap hat) then my guess would be the master.
You can test the Master Cylinder by pumping up the brakes a few pumps worth and on the last pump hold the brake pedal down, like you are hitting them hard. If there is a small leak, or faulty seals within the system, the pedal will slowly drop. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Sun Jan 08, 2023 5:00 pm Post subject: Re: 1957 Sedan - Hardly any brakes - master cylinder? |
The only problem I've ever seen from no brake pedal free play is the shoes or pads remain slightly applied. The friction of the linings causes the brakes to over heat and expand which exacerbates the problem.
Have you removed the driver's side floor pan mat or carpet and inspected the front to rear brake line? If that line leaks it's usually up by the pedal cluster, the fluid will leak under the mat and won't be evident without pulling up the mat. How is the level in the reservoir? |
Posted: Sun Jan 08, 2023 5:16 pm Post subject: Re: 1957 Sedan - Hardly any brakes - master cylinder? |
3foldfolly wrote: |
No leaks. Reservoir is full to the top. _________________ 1957 Oval Window - original pan, body, and engine |
Posted: Sun Jan 08, 2023 5:54 pm Post subject: Re: 1957 Sedan - Hardly any brakes - master cylinder? |
Sounds like the MC is faulty. Time to replace it. No, you do not need to remove the pedal assembly to change out the MC.
Here is the Bentley troubleshooting chart.
TDCTDI wrote: |
