BatesEV Samba Member
Joined: October 01, 2019 Posts: 182 Location: Los Angeles
Posted: Sun Jan 08, 2023 4:00 pm Post subject: Diesel heater in Aux location |
So I’ve been debating about this idea for a long time. I finally pulled the trigger and ordered the 3kw Vevor kit. I didn’t want to cut the van and I wanted to have a clean install. So I removed the factory heater since the PO disconnected it. I used a drawer I’ve collected and a few other parts to make a clean install in my opinion. I’m kinda excited to get out and try it. I had a small tank around so I used that before I invest in fabricating an under mount. I use the factory switch to power the system down. I wired it to the house batteries. Let me know any tips or opinions.
bcolins Samba Member
Joined: December 04, 2020 Posts: 729 Location: Austin, TX
Posted: Thu Jan 12, 2023 10:51 am Post subject: Re: Diesel heater in Aux location |
Can you tell us what we are looking at in your pics please? Most importantly,....where did you plumb the heater output into the EV,...I have seen another plumb his up into the existing rear floor mounted heater vent behind the passenger seat.
Brian in Austin
MrPulldown Samba Member
Joined: September 08, 2020 Posts: 649 Location: Truckee
Posted: Thu Jan 12, 2023 1:27 pm Post subject: Re: Diesel heater in Aux location |
I think that I would have mounted the heater sideways (I think you can do that with those) and ran the intake and exhaust out the side of the drawer. Out the bottom just looks like it is ready to get ripped off. Maybe that is just me and I do a lot of dirt miles. But even keeping it out of road debris is a good thing. _________________ 2002 EVC |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Thu Jan 12, 2023 2:25 pm Post subject: Re: Diesel heater in Aux location |
bcolins- look up "chinese diesel heater" or similar. There's an epic thread about them over in the vanagon forum. It's basically a small standalone furnace separate from the vehicle. I personally wouldn't use one driving down the road, but in a non-EVC eurovan that doesn't have the Suburban furnace? Freaking sweet for camping! I assume the hot air vents through the same vents the stock aux heater was using.
OP- this looks awesome, at first I thought you had the exhaust plumbed all the way out back, now I see that's the first muffler. Is there anyway to tuck that up a little tighter and, obvs, be careful leaving your side window cracked while sleeping if furnace running. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Thu Jan 12, 2023 4:41 pm Post subject: Re: Diesel heater in Aux location |
mikemtnbike wrote: |
bcolins- look up "chinese diesel heater" or similar. There's an epic thread about them over in the vanagon forum. It's basically a small standalone furnace separate from the vehicle. |
Am familiar with them,...just wasnt clear where and how he mounted and plumbed it,....so was asking for details. |
Posted: Wed Jan 18, 2023 5:47 am Post subject: Re: Diesel heater in Aux location |
Originally I was going to mount it sideways. But the glow plug would of been on the bottom and read that was a no go. That is if I didn’t reroute the intake. The heat output goes through the floor. I had a shop vac attachment that screwed into place.
I just did a trip with it and did some dispersed camping and off road driving in Death Valley. Nothing got caught. Only install issue was the line melted where I routed it in the engine compartment. I had installed the ACU header and it makes some heat. Luckily I bring spares. Running it at night with a low of 32 it kept it well above the setting temp. I was running it in alpine mode at 8c and it was keeping it about 17c according to the controller. For 7 hours of run time I used only .5 gallons.
My reasoning behind all of this was I didn’t want to hack the van up and I had scrap laying around and time. |
PatJr Samba Member
Posted: Wed Jan 18, 2023 8:55 am Post subject: Re: Diesel heater in Aux location |
nice!
thanks for posting the project _________________ #############################################
1970 Transporter a orange one
almond Samba Member
Posted: Sun Jan 29, 2023 3:43 pm Post subject: Re: Diesel heater in Aux location |
I hosed mine by driving through too large a puddle.
These things are designed to be mounted inside, so you should take steps to waterproof it as much as possible while under the van.
Water can also come in the "cold side" air intake too and mess up the electronics.
They work great though |
Posted: Wed Feb 01, 2023 6:41 am Post subject: Re: Diesel heater in Aux location |
Thanks for the tip. Luckily it’s first putting was during a big rain storm. I tried to position it where it wouldn’t get splash up and sealed off the intake to the fresh air boot. If water does get in it can drain out as I’ve learned steam is worse than water sometimes.
And I have to say I wish I went for the 2k version but the 3k was too good of a deal |
