Any interest in Honda K-swap motor mount kit? |
Yes |
38% |
[ 32 ] |
Yes - if there was a full kit |
47% |
[ 40 ] |
Intriguing but No |
8% |
[ 7 ] |
No way |
5% |
[ 5 ] |
Total Votes : 84 |
Pchill2 Samba Member
Joined: November 19, 2021 Posts: 406 Location: Georgia
Posted: Tue Jan 10, 2023 4:01 pm Post subject: Any interest in Honda K-swap motor mount kit? |
I’ve been cruising around for close to a year now in my K24 powered syncro and I absolutely love it. It seems to me that some of the more traditional Vanagon swap platforms are getting expensive or hard to find and I think the Honda motors could be a viable option.
My build thread outlines all of the parts necessary and costs associated with a complete conversion along with a few pictures of the parts I had to fabricate to install the engine and exhaust. I know some of you all are pretty savvy and could easily do the same but how many out there would actually take the plunge if a mount kit was available? How many would take the plunge if a full plug and play kit was available?
Build Thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=766259
I bring this up because I know there’s at least one on here for sure (I won’t name names). I’ve been thinking through a redesign of my motor mount system that would be pretty easy for me to fabricate if there’s some interest. _________________ 87 Syncro Westy
Honda K24 swap
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Tue Jan 10, 2023 4:20 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
I removed the thick foam sound deadening and replaced it with a thinner dynamat style sound deadening material and also trimmed some sections of the ribbing. An aftermarket low profile valve cover was also necessary. No raised deck lid necessary. _________________ 87 Syncro Westy
Honda K24 swap |
Posted: Tue Jan 10, 2023 4:25 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
Honda K24 swap |
thatbaldwinlife Samba Member
Joined: August 01, 2011 Posts: 777 Location: Out exploring
Posted: Tue Jan 10, 2023 4:44 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
How is the ground clearance vs stock or other popular swaps? That is more important to me than raised deck lid.
nate _________________ 1987 Westy
Insta: @Thatbaldwinlife
Vanagon Adventure and DIY videos:
That Baldwin Life YouTube Channel |
Posted: Tue Jan 10, 2023 4:50 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
thatbaldwinlife wrote: |
nate |
I believe it’s still more ground clearance than a Subaru with a high clearance oil pan but it’s hard to tell based on info I’ve seen on here.
I’m running 215/70R16s
Oil pan clearance at ride height:
Hub center to wheel lip:
Ground to Wheel lip:
Honda K24 swap
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Tue Jan 10, 2023 5:40 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
personally i would cast myself whatever i needed, or fab my own, but i realize not everyone has a shop like that so this seems like a good source for folks who want to focus on the swap and not the 'figuring it out'. what are the mounts made from? are you going to make them, or do you farm that out? _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
Posted: Tue Jan 10, 2023 7:06 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
Welded tube and plate. Very similar to an old school 911 engine bar. _________________ 87 Syncro Westy
Honda K24 swap |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Tue Jan 10, 2023 7:29 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
Pchill2 wrote: |
Welded tube and plate. Very similar to an old school 911 engine bar. |
what thicknesses/material? i only ask because you had said on your build thread that you had some issues with your mounts twisting from stress when you first ran your swap? was curious what you changed about these. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
Posted: Tue Jan 10, 2023 7:37 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
The isolators were too soft allowing more rearward compliance than I’d like during acceleration. I chose the cheapest aftermarket isolators I found but it didn’t have anything to do with the actual engine cradle.
I used 1/8” wall tube and 3/16” 4130 plate. The structure is plenty strong. _________________ 87 Syncro Westy
Honda K24 swap |
Posted: Tue Jan 10, 2023 7:42 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
ALIKA T3 wrote: |
The clearance can be measured from the lowest of the engine to the chassis, or say the skirt to have a reference anybody can use. |
Added a third reference measurement (ground to fender lip) so you guys can gauge what clearance you would based on your ground to fender lip measurement with your suspension and tire setup. _________________ 87 Syncro Westy
Honda K24 swap |
danfromsyr Samba Member
Posted: Wed Jan 11, 2023 5:49 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
besides lack of familiarity of honda cars and parts
what years & models we're the viable K24s used in?
most of the other older donor vehicles are aging out and getting harder to find viable donor vehicles. _________________
Abscate wrote: |
Borg Samba Member
Joined: October 18, 2012 Posts: 120 Location: Western Washington
Posted: Wed Jan 11, 2023 12:00 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
As someone with a lot of miles on a now tired EJ22 the thought of swapping to something else is intriguing. _________________ Steve |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Wed Jan 11, 2023 12:08 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
Borg wrote: |
As someone with a lot of miles on a now tired EJ22 the thought of swapping to something else is intriguing. |
Thought about doing a new OEM EJ25 short block with your current heads?
But even with my EJ22 I am still interested in the honda K-swap. _________________ Brandon
Instagram @joannthevan |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Wed Jan 11, 2023 12:18 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
This makes me want to buy another van just to put one of these in it! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Wed Jan 11, 2023 12:59 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
also a question in the engine management.
for a swap these would be a stand alone system?
or harvest the harness and ECM from the donor car?
trying to get a idea on the DIY levels here.. _________________
Abscate wrote: |
Posted: Wed Jan 11, 2023 2:13 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
danfromsyr wrote: |
trying to get a idea on the DIY levels here.. |
K-Tuner, Hondata K-Pro, Haltech, or AEM ECU would be required for the swap.
I am running Hondata K-Pro but I believe all of the ECM manufacturers have pre-loaded base maps available to get you running. Likely every tuner with a dyno has used and is familiar with K-series engines and tuning them. I am running a base map with a tweaked fuel compensation value without issues and it makes plenty of power and low end torque.
I've pulled together a complete parts list on my build thread with costs. Basically 90% of the swap is done using off the shelf aftermarket parts that are readily available, including the wiring harness which I've seen on amazon for $79 (my harness is motorsport grade $$$$). The fabricated components were the engine cradle and the exhaust pipe which I'm pondering making a few sets.
The ECM to Vanagon adaptor harness is a Hybrid Racing universal K-swap harness pinned to the Vanagon black box gauge cluster connector. I believe it was only 5 wire connections to get everything running properly.
In my opinion, this swap is about as DIY friendly as it gets with the exception of the full plug and play $15k+ options out there. I did mine for just over $6k but already had most of the parts from my other car. Costs could come down significantly with the cheaper harness and plumbing with something other than expensive AN fittings like I did. _________________ 87 Syncro Westy
Honda K24 swap |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Wed Jan 11, 2023 2:25 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
It's an intriguing engine, very similar to the Zetec used by Bostig, but a bit more modern. You may want to check out the Bostig site to get the idea of a full kit.
One question, it looks like you didn't use a catalytic converter? How will that play with people who need to pass emissions checks? _________________ Currently:
