Where are you putting your temp sensor |
Oil relief plug |
23% |
[ 9 ] |
Drain plug |
18% |
[ 7 ] |
oil pressure idiot light hole |
10% |
[ 4 ] |
external cooler |
28% |
[ 11 ] |
type 3 block off |
18% |
[ 7 ] |
Total Votes : 38 |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Thu Feb 02, 2023 1:40 pm Post subject: Re: Temp sensor location poll |
Yep that's it , got it from a guy on here , I haven't seen him in a while? all I can remember was his sig. line said:
Hoses & Fittings _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Mon Feb 06, 2023 6:55 pm Post subject: Re: Temp sensor location poll |
Lingwendil wrote: |
No drilling or tapping required, all bolts together. |
I just ordered this same dual in/out filter mount. Where can I get the threaded adapters to install the VDO temp/pressure sending units……Part numbers would be great.
Also would they be available in a retailer plumbing department?
Thanks |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Dangib Samba Member
Joined: October 05, 2011 Posts: 95 Location: pittsburgh
Posted: Tue May 23, 2023 10:21 am Post subject: Re: Temp sensor location poll |
I ended up using oil relief and have few trips on the buggy and seems to work well as a general idea of temp my VDO reads about 180-185 typically. |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 813 Location: San Juan Islands
Posted: Tue May 23, 2023 10:49 am Post subject: Re: Temp sensor location poll |
Dangib wrote: |
Was thinking of moving mine to the oil relief. Currently at the drain plug and wonder if it reads a little cooler because of air passing over it? _________________ When I set my timing, why do I flush, then take a pee? |
