riva Samba Member
Posted: Wed Jan 18, 2023 12:15 pm Post subject: Who is using wheel adapters? Please post your 1st hand info! |
I did some searching, but my search-foo may be lacking. This is one I saw:
https://www.thesamba.com/vw/forum/viewtopic.php?t=773364&highlight=offset
Slalombuggy had some interesting input on adapter use in that one, which I greatly appreciate.
I thought it would make a good thread if those with 1st hand experience running wheel adapters would post their setups together in a thread. I'm assuming only high offset wheels would be successfully paired with adapters because of the issues which Slalombuggy mentions above. But who knows.
Hello... is there dapter data in there? Just nod if you can hear me. Is there anybody home? |
oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Wed Jan 18, 2023 8:50 pm Post subject: Re: Who is using wheel adapters? Please post your 1st hand info! |
There was a pair of stamped sheet metal wide 5 to Chevy adaptors on my sand rail when I bought it. That was one of the very first things I changed, I did not trust them at all!
There was cast aluminum VW 4 bolt to Chevy adaptors on all 4 wheels that came on my Manx copy. I am not a fan of adaptors of any kind but I must admit that these ones survived for 46 years on that car without failing. While they did not fail they did cause the handling problems outlined in the thread link you posted. I am happy they are not on the front anymore and quite pleased with the difference that made. The rears will be coming off too not because they are causing any issues back there but just to have the same bolt pattern front and rear. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Jan 19, 2023 6:39 pm Post subject: Re: Who is using wheel adapters? Please post your 1st hand info! |
I have been running VW wide 5 to Porsche 5 adapters on the rear of my Micro since 2008 with no issue. They are the thick aluminum style not stamped steel. I also have the drums studded and lug nuts, not lug bolts _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1197 Location: Vancouver, BC
Posted: Thu Feb 08, 2024 10:37 am Post subject: Re: Who is using wheel adapters? Please post your 1st hand info! |
I've been using 5/8" 5x112 to 5x114.3 adapters on my 76 Westy to run Chrysler rims that I already had. They work well and I haven't had any issues with them over 20,000 miles so far.
_________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
oprn Samba Member
Posted: Thu Feb 08, 2024 3:15 pm Post subject: Re: Who is using wheel adapters? Please post your 1st hand info! |
I just found out recently that wheel spacers and adaptors are not legal in Alberta. I find that interesting because my Buggy passed an inspection with them on as did several others hat I am aware of. Also Porsche used spacers on some of their cars right from the factory. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
