esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu Jan 19, 2023 5:23 pm Post subject: Convertible heater channel, and reinforcement rail replacement |
I've been searching through threads and pictures hoping to get a clearer idea of what I'm up against, and there are a lot of posts asking questions, but not many clear answers or pictures. So here goes:
This is a clients 65 vert, that was a running project, but the support rails were pretty much rusted completely away, and the floors were thin. A previous shop had started to do the work, but got cold feet and returned the car before they did any real damage. I received it completely unbolted from the pan, some door bracing welded in, and with the drivers side front cowl reinforcement partially cut away.
Here is the bracing. Not how I might have gone about it, but no point in starting over..
First day was removing both floors and the bottom plate of the passenger side heater channel.
This is the driver side cowl reinforcement thats butchered
Driver side rear reinforcement
Passenger side cowl reinforcement
Passenger side rear
You know the drill
Here is the lower brace I added between the a and b pillars, it's 1/2" solid bar. I hated this bracing at first, but it's installed in a way that allows the door to stay mounted, so I can continually check the gap. Maybe it's better than I thought
Separating the reinforcements from the heater channel.
Next is the part that took a ton of time and patience. AFter cutting the lower heater channel plate free, I horsed on the heater duct that lives inside till it broke free. Then, I very carefully cut out and removed the heater channel from underneath, without disturbing the front or rear reinforcement panels. I had the full arsenal of tools, 3" air grinder, air chisel, needle nose vice grips, air drill, various cold chisels, and a die grinder with a sharp carbide burr.
Still have a few hours of cleanup and sandblasting to clean up the rust. At this point I removed the center piece of heater channel and checked the door gap
Not bad
So, my goal is to do all of this work lifting the car only as little as needed to get the pieces in. Floor pans get punched for welds.
Here I have test fitted the Wolfsburg west rail to the Klassic fab heater channel, and then bolted up the WW floor pan. Everything lines up pretty well.
Here you can see how the rail and heater channel line up. I'm going to stitch weld the bottom plate of the channel to the reinforcement rail, and then seam seal the edges
So far so good.
I have a plan for getting the heater channel in, and then the floor pan. I'd like to have all of the body bolts in and snug before any welding starts. More pics will come once that happens
SD _________________ modok wrote:
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Thu Jan 19, 2023 6:01 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
That's one heckuva layout table _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
esde Samba Member
Posted: Thu Jan 19, 2023 7:31 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
Busstom wrote: |
That's one heckuva layout table |
Yeah, its a 5'x11' chunk of some massive milling machine bed. The local steel surplus yard scrapped it and offered up a few chunks. Weighs a shade over 7k pounds, took two forklifts to get it into place. But it is absolutely perfectly flat _________________ modok wrote:
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Fri Jan 20, 2023 5:42 am Post subject: Re: convertible heater channel, and reinforcement rail replacement |
I have a 65 convertible if you need any pictures. Looking forward to the progress. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Fri Jan 20, 2023 10:59 am Post subject: Re: convertible heater channel, and reinforcement rail replacement |
brilliant stuff. lots of good info for future cabrio restorers _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
esde Samba Member
Posted: Fri Jan 20, 2023 12:45 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
bigdog1962 wrote: |
I have a 65 convertible if you need any pictures. Looking forward to the progress. |
I'd love to see how the cowl reinforcement panels meet the bottom edge of the heater channel, and the opening for the heat vent. This are the first spots that rot out, so knowing what they used to look like is tough _________________ modok wrote:
Puppy67 Samba Member
Joined: October 04, 2022 Posts: 221 Location: Bristol, UK
Posted: Fri Jan 20, 2023 1:03 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
This is from a '67/8, but I think it's pretty similar.
esde Samba Member
Posted: Fri Jan 20, 2023 1:19 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
MORE:
got the passenger side floor rough fitted, and assembled the passenger side heater channel/ support rail. Important to note: When figuring out where the channel and support rail meet, you have to be sure you leave enough room for the outer folded edge of the floor pan. If you just lined up the holes so they were centered with each other, or lined up the edges so it was pretty, there's a high probability the pan would not bolt up easily. I bolted it all together and scribed the meeting points, and a few holes on the support rail needed to be enlarged slightly.
Then punched a 5/16 hole every few inches, on both sides. I decided this would look neater then just welding the seam.
cleaned paint from the area around the welds
I cleaned and hit everything with SEM weld through primer. Use your imagination
Clamped using my scribe marks
Welding like this I like more heat and less wire feed. Using the 260 Esab voltage was 20 and feed 180ipm, with 030 wire
A few places the parts didn't meet in a way that worked for a rosette weld
There it is man. Substantially heavier than your average channel.
Removed the carpet bar at the heater vent, and saved it for when I fix the reinforcing panel
Buzzed the green paint off everything that will be inaccessible once installed and hit it with weld through primer
Done.
For those interested, this post was about 6 hours of work, in a well lit shop with all of my tools at hand, and good music keeping me going.
If I was doing this at home in the barn I imagine it would take a bit longer
Tools at hand
Few other bits
to make the floor easier to fit, I cut off the rear lip that it rests on, this is the little extra part that is included separately with the WW pans. This way, you can slip it in without lifting the body so high. I'll fix the rear lip later
And the carpet bar under the door is different . See old vs what comes on the KF heater channel. I'll deal with that last as it's likely to get banged up while working. I think a hood seal channel from Virtanen might be very close and work well.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Jan 20, 2023 2:00 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
Reed's VW Restoration in WA builds their heater channels in house! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
esde Samba Member
Posted: Fri Jan 20, 2023 2:49 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
Mike Fisher wrote: |
Reed's VW Restoration in WA builds their heater channels in house! |
From scratch? Or do they start with someone else's parts and modify it to suit? I looked through their Facebook pictures and the only vert I saw looked like it was was wearing funky green channels. _________________ modok wrote:
Posted: Fri Jan 20, 2023 2:53 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
esde wrote: |
From scratch? Or do they start with someone else's parts and modify it to suit? I looked through their Facebook pictures and the only vert I saw looked like it was was wearing funky green channels. |
The rebuild I was looking at they fabricated new parts themselves.
I don't think it was a vert.
Your local Hot Rod Shop might help fabricate for you. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Fri Jan 20, 2023 3:06 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
Looks like this project landed in the right hands, owner should sleep peacefully. It's more than I could chew, big equipped shop, barn, or my little garage. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
esde Samba Member
Posted: Fri Jan 20, 2023 9:28 pm Post subject: Re: convertible heater channel, and reinforcement rail replacement |
Puppy67 wrote: |
Posted: Sun Jan 22, 2023 8:33 am Post subject: Re: Convertible heater channel, and reinforcement rail replacement |
That's the best I have. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
esde Samba Member
Posted: Mon Jan 23, 2023 8:22 pm Post subject: Re: Convertible heater channel, and reinforcement rail replacement |
bigdog1962 thank you!
Rainy Monday, got right into it.
Spent a little time cutting more rust away on the firewall to fit this piece.
https://www.klassicfab.com/product/kft1-61-right-side-lower-inner-front-firewall-4in-high-all-years/
I won't know exactly where it fits till the heater channel is in, but I had to at least get it fished into place. Also got the inside of everything cleaned up and treated with OSPHO, and then painted. OK, time to see if the damned pieces will fit back together. Here is how I started, at the front, with the rear of the heater channel hanging down. I had to cut and lift a flap in order to get to the last bits of the old rusted heater channel, and it made fitting this end back in easier.
Here, from the inside
Next detail. The damned defroster tube. It's paper and foil, so the bottom 6" was just mush. And on a vert there's a stiffener panel that prevents you from getting your hand down there from behind the hood hinge, so working on any of it is a real PITA. I had just done some oval heater channels, and had the early metal defroster tubes. They're a tight slip fit into the later paper tube. I slipped a piece up from below into what was left of the paper tube, and then tacked the metal tube to the heater channel. DONE.
Started to jack the heater channel into place, until the rear end hit the floor support that sticks out from the torsion housing. Lifting the body an inch or so did the trick (wood block at the mount)
After considerable banging and prying, it's in.
but hanging a half inch from where it needs to go
Then came the fun part, which was getting to floor pan in. It fought me for a bit, and would have gone much easier with 4 hands, but eventually my persistence payed off. All pan bolts are in on that side, so kept pushing the heater channel into place
First obstacle. The carpet bar I said I'd remove later is in the way, so later is now. You can see it hits the curved panel and keeps me from raising the channel tight to the B pillar
After that it slipped home easily
tight fit
More patching to be done
General overview after I called it a day
From here, I need to get the front and rear pan gasket set down, and the front and rear body mounts in place. Everything has to be aligned and snug before I start welding anything. My door gap is a little tighter at the top than bottom, so I'll experiment with ways to correct that before I make any commitments.
Tomorrow I start chopping out the drivers side and fussing with the mounts.
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Mon Jan 23, 2023 11:33 pm Post subject: Re: Convertible heater channel, and reinforcement rail replacement |
Looking great! I welded in adjusters into my angle iron bracing. Worked out awesome when it came time to tweak the 54s body! Maybe something like that would help out.
_________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Tue Jan 24, 2023 1:14 am Post subject: Re: Convertible heater channel, and reinforcement rail replacement |
Great work.
Just to warn you though, the cowl reinforcement panels may need to come off then be refitted after welding in the channels. Some of the seams cannot be reached with them in place.
esde Samba Member
Posted: Tue Jan 24, 2023 6:20 am Post subject: Re: Convertible heater channel, and reinforcement rail replacement |
Puppy67 wrote: |
Great work.
Yeah, I know it's coming.
Here's my reasoning for leaving that part till later. The cowl support in front of the A pillar and the support in the trunk are there to take some of the stress off the A pillar, and keep the windshield frame from flapping in the breeze. There's no way I was going to have them completely loose at the same time as I had removed the heater channels. Currently the plan is to make a cut in the cowl support and peel it back after the door gaps are set and I've gotten all of the exposed welds complete. I've got to repair the bottom 2" of the support anyway, so welding the seam isn't a big deal.
esde Samba Member
Posted: Tue Jan 24, 2023 7:30 pm Post subject: Re: Convertible heater channel, and reinforcement rail replacement |
Here are the front windshield supports, that mount just forward of the hood hinges. You can just see the metal defroster tube that I used slipped inside the original paper one
Then more heater channel removal. This side has been repaired before, with rivets, bogger welded angle iron, and roof cement.
I cut what remained of the bottom off, and just left the top between the a and b pillar. I'll add a lower brace there before cutting the channel completely out, but for now I don't need another thing to hit my head on.
Rust where the rear crossmember meets the heater channel end, typical. Even the shitty patch with roof cement is typical
Here you can see the front lower quarter has been welded before. It's pretty ugly and will get mostly cut out
The rear cleaned up pretty easily. I'll leave the voltage regulator here, but I'm tossing the ammeter and heavy gauge red wires.
Carnage
