ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2649 Location: West Coast (Michigan's)
Posted: Thu Jan 19, 2023 11:46 pm Post subject: getting the most out of Empi Race prep CV's |
These have been out for awhile and I'm wondering how I can get more travel out of mine. I find I get somewhere around 12-15 degrees before I start hearing clacking. I'm only able to get around 10" of travel which seems awful low. (Am I right to think this?)
Anyway, I'm preparing to upgrade from my useless airbag suspension to some kind of coilover setup. I want to incorporate some kind of sag setting(ride height I've heard should be 40% of travel) which will limit my travel somewhat but work the way it's supposed to. With the bags your limited and if you want the most support you give up any upward travel, meaning ride height is always the top of your travel. Basically where ever your limit straps stop.
So I'm asking if anyone knows of a good write-up on massaging these race preps to get the most articulation so I can get my shock setup right the first time. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Fri Jan 20, 2023 2:45 am Post subject: Re: getting the most out of Empi Race prep CV's |
Found some vids about clocking and polishing. I'm sure I clocked em when I installed but since my angles don't match what others have I need to take these apart and check things. They have very little use but I imagine a cleaning and some new grease wouldn't be a bad thing.
Leave suggestions if you want in the meantime
thanks _________________ Brian H.
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Fri Jan 20, 2023 7:49 am Post subject: Re: getting the most out of Empi Race prep CV's |
I have the empi race cv’s, type 2, that are advertised at up to 22 degrees range, as I remember and. When I set the spring plate stop for maximum travel before binding I measured about 21 degrees. All I did was clock them. You must be using type 1 cv’s but I would suspect they should make the maximums travel/degrees advertised. |
77charger Samba Member
Posted: Fri Jan 20, 2023 4:17 pm Post subject: Re: getting the most out of Empi Race prep CV's |
Im using the type 2 race prep ones at 22-23 degrees with no issues.I do polish them up a little too.Then clock them _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
Posted: Sat Jan 21, 2023 11:46 am Post subject: Re: getting the most out of Empi Race prep CV's |
Sorry guys. I finally got out to the shop to check myself. They're running around 19 degrees which isn't as terrible as I thought. I think i just got confused ( common these days ) after installing new limit straps. My old were stretching too far. I felt like in the process I had to limit a lot more than in the past. But i was full of it. Measure first next time, then complain. _________________ Brian H.
