BMFBMF Samba Member
Joined: November 13, 2020 Posts: 354 Location: Swtzerland
Posted: Fri Jan 20, 2023 9:41 am Post subject: After 50 years there's some light in the tunnel. |
Hi Folks, finally bit he bullet and went into the tunnel to replace the gearchange coupling and plastic bush. Also took out the pedals. Got some questions ......
Guess I should weld this guy back up to full strength, up or is it OK for now?
The top and sides of the tunnel look amazing , as though they just left the factory. Little bit of rust on the bottom. Should I try to get some rust off and then hit it with cavity spray? any other ideas?
This picture below is taken though the gear-lever hole. White cord was tied to the tube when I pulled it out , hopefully to help pull it back in.
Better picture of the bottom with the surface rust..
_________________ -----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day. |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2234 Location: Medford, OR
Posted: Fri Jan 20, 2023 10:05 am Post subject: Re: After 50 years there's some light in the tunnel. |
Clutch hook doesn’t look like it will snap tomorrow, but while you’ve got it out, may as well address it.
I recently pulled my pedal assembly apart, cleaned, lubed, and reassembled.
For the hook, I welded in a bolt and brass bushing to eliminate the hook. There are similar assemblies that can be purchased in the classifieds. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 849 Location: South Florida
Posted: Fri Jan 20, 2023 12:12 pm Post subject: Re: After 50 years there's some light in the tunnel. |
BMFBMF wrote: |
... Should I try to get some rust off and then hit it with cavity spray? ... |
There's a good product for this, but it's out of stock currently. Maybe you can find it elswhere? Here's a link:
https://www.eastwood.com/eastwood-internal-frame-coating-14oz-aerosol.html |
viiking Samba Member
Joined: May 10, 2013 Posts: 2666 Location: Sydney Australia
Posted: Fri Jan 20, 2023 3:14 pm Post subject: Re: After 50 years there's some light in the tunnel. |
I painted mine while the pan was on a rotisserie. However if you can’t find a decent paint while it’s a roller buy some lanolin spray and coat the insides. It’ll stop rust and smell wonderful. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31271 Location: Hot Arizona
Posted: Fri Jan 20, 2023 4:55 pm Post subject: Re: After 50 years there's some light in the tunnel. |
BMFBMF wrote: |
I think mine was worse. Load up with grease when re-installing.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
BMFBMF Samba Member
Posted: Sun Jan 22, 2023 12:21 am Post subject: Re: After 50 years there's some light in the tunnel. |
Thanks for all the input folks, did some poking around last night and most of what looked like rust was actually just dust that it collected around the water drain hole. Wiped it down with a damp cloth and it's looking pretty good.
For the little traces of rust that are there, I wonder if I should paint it with one of those rust converter paints, before hitting it with the cavity spray?
After 50 years the rubber drain bung under the tunnel was as hard as rock, had to pour a bit of boiling water on it to soften it up enough to get it out. Otherwise still in perfect shape, it's amazing how old rubber can last. _________________ -----Slava Ukraini-----
Maddel Samba Member
Posted: Sun Jan 22, 2023 2:42 am Post subject: Re: After 50 years there's some light in the tunnel. |
BMFBMF wrote: |
The top and sides of the tunnel look amazing , as though they just left the factory. Little bit of rust on the bottom. Should I try to get some rust off and then hit it with cavity spray? any other ideas? |
I used Fluid Film Liquid A: http://fluidfilm.de/en/produkte/liquid-a/203/ |
wcfvw69 Samba Purist
Posted: Sun Jan 22, 2023 5:48 am Post subject: Re: After 50 years there's some light in the tunnel. |
Maddel wrote: |
BMFBMF wrote: |
I'd use Fluid Film in that tunnel as well. It can prevent any future rust from developing as well. _________________ Contact me at [email protected]
The Samba member since 2004.
edjose17 Samba Member
Joined: November 04, 2019 Posts: 24 Location: Puerto Rico
Posted: Sun Jan 22, 2023 5:57 am Post subject: Re: After 50 years there's some light in the tunnel. |
Cusser
How many miles your Beetle had when you saw this?
Cusser wrote: |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1354 Location: Wichita, KS
Posted: Sun Jan 22, 2023 7:07 am Post subject: Re: After 50 years there's some light in the tunnel. |
If you’re worried about wear in the clutch hook, you might consider looking into one of these (ref. link below). I ordered and installed one several years ago, when I was refurbishing & restoring my floor pedal assembly. It’s worked perfectly so far.
https://www.thesamba.com/vw/classifieds/detail.php?id=1087010 _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
frenchroast Samba Member
Posted: Sun Jan 22, 2023 8:49 am Post subject: Re: After 50 years there's some light in the tunnel. |
My hook has about that much wear and I run it without worry. I drilled a small hole in the hook tip for a cotter pin to keep the cable hook from falling off on install. Some people use a small zip tie or rubber band. |
Posted: Sun Jan 22, 2023 10:58 am Post subject: Re: After 50 years there's some light in the tunnel. |
edjose17 wrote: |
Cusser
Cusser wrote: |
My 1967 bug had roughly 130k original miles on it when I pulled the pedal assembly to service and lube it. My clutch hook was worn just a bit more. I welded it up. I then smoothed out the area where the clutch cable rides and lubed it up with wheel bearing grease.
My 67' bug is primarily a weekend ride or doing errands during the nice weather during the week. So, it only gets a couple thousand miles put on it a year like most of our air cooled VW's these days. It should be good for a few decades before requiring any additional work. _________________ Contact me at [email protected]
BMFBMF Samba Member
Posted: Sun Jan 22, 2023 12:50 pm Post subject: Re: After 50 years there's some light in the tunnel. |
Thanks for the input guys, its a "right hand drive" as in "correct-hand drive " 🤣so the modified clutch pedal seems to be non existant for this type.
Once I cleared ou the dust from the tunnel around the drain , the metal seems in super good condition. Yee-ha....
BMFBMF Samba Member
Posted: Tue Jan 24, 2023 1:33 am Post subject: Re: After 50 years there's some light in the tunnel. |
Got a friend who works at CERN who is going to build the hook back up for me.
I just wanted to add that I'm now going to remove the drain plug every few years to clean it out to make sure water can easily drain out.
If you've not done that for many years, I suggest you check it out, dust collect there and can cause water to stop draining and rot out the tunnel. _________________ -----Slava Ukraini-----
Posted: Tue Jan 24, 2023 3:49 am Post subject: Re: After 50 years there's some light in the tunnel. |
And if you can’t find the right drain plug to use, you can fit an old tubeless tyre stem in there.
That’ll confuse people who want to know what you’re blowing up. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Cusser Samba Member
Posted: Tue Jan 24, 2023 7:34 am Post subject: Re: After 50 years there's some light in the tunnel. |
edjose17 wrote: |
Cusser
Cusser wrote: |
That was from my 1971 Super Convertible, 140K miles.
The one on my 1970 sedan lasted longer, like 200K. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Tue Jan 24, 2023 9:10 am Post subject: Re: After 50 years there's some light in the tunnel. |
Welding that may change its temper and wear out faster. I'd either replace it, or spend time smoothing and deburring it, then use lots of sticky moly-type grease on it. Do the same for the cable eye. Casting flash can create sharp edges and stress points. |
vwoldbug Samba Member
Posted: Tue Jan 24, 2023 9:21 am Post subject: Re: After 50 years there's some light in the tunnel. |
Why wouldn't you fix it or replace it before it breaks on the road . Good luck |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6558 Location: Houston, Texas
Posted: Tue Jan 24, 2023 10:46 am Post subject: Re: After 50 years there's some light in the tunnel. |
baldessariclan wrote: |
https://www.thesamba.com/vw/classifieds/detail.php?id=1087010 |
That's a nice idea. _________________ www.vwnos.com [email protected]
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76761 Location: Sneaking up behind you
Posted: Tue Jan 24, 2023 10:55 am Post subject: Re: After 50 years there's some light in the tunnel. |
I bought that when mine failed.
_________________ Glenn
Member #1009
#BlueSquare |
