KTPhil Samba Member
Posted: Tue Jan 24, 2023 11:05 am Post subject: Re: After 50 years there's some light in the tunnel. |
If an original part lasted 50 years, why try to improve on it? Most fail because of crappy parts, lack of attention to deburring, and lack of lubrication. I don't see the need for a fancier solution. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Jan 24, 2023 11:06 am Post subject: Re: After 50 years there's some light in the tunnel. |
KTPhil wrote: |
Because NOS original parts are not readily available, the aftermarket stuff is crap and too soft and there's a quality upgrade that works better than the original. _________________ Glenn
Member #1009
#BlueSquare |
BMFBMF Samba Member
Joined: November 13, 2020 Posts: 358 Location: Swtzerland
Posted: Tue Jan 24, 2023 1:36 pm Post subject: Re: After 50 years there's some light in the tunnel. |
I'm sure the hook it just mild steel plate so I dont think the welding will affect it negatively, but I could be wrong. Ive got 150 k miles on it so its still looking good for that.
Cant buy a replacement as the RHD assembly is a bit more involved and I've not seen the "bolt/nut" type upgrade for RHDs clutch cable attachment. All the orignal bushes in mine are still great.
_________________ -----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day. |
BMFBMF Samba Member
Posted: Wed Jan 25, 2023 3:36 am Post subject: Re: After 50 years there's some light in the tunnel. |
A quick question to you knowledgeable folks, has anyone a good idea about cleaning the dust out of the tunnel?
Old damp Tshirt on the end of a stick?
I don't want to spray the cavity spray onto the dust if I can help it, I can get my fat arm into the coupling hole and wipes that area with damp cloth but don't know how to attack the tunnel to the front of that.
Cheers
BMF _________________ -----Slava Ukraini-----
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Wed Jan 25, 2023 5:45 am Post subject: Re: After 50 years there's some light in the tunnel. |
Just wash it out with some soapy water then a hose then use a heat gun or hairdryer to dry it before hitting it with cavity wax. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
BMFBMF Samba Member
Posted: Sun Jan 29, 2023 1:58 pm Post subject: Re: After 50 years there's some light in the tunnel. |
Hi Folks, got a little time to have a closer look in the tunnel. Found some corrosion in the front. I believe due to a leaking master cylinder 25 years ago.
I do plan to wash it out before I treat it internally. One question is what this trough shaped thing is circled in red. If I spray water in the tunnel will it run though that trough elsewhere into the car?
This is the trough seen from the pedal hole.
And this is the trough seen from the front
This is what the corrosion looks like up front in a closer shot. I'm going to try to get my arm in there with a steel brush before I wash it out.
Thanks a million for any advice folks. _________________ -----Slava Ukraini-----
BMFBMF Samba Member
Posted: Mon Jan 30, 2023 8:33 am Post subject: Re: After 50 years there's some light in the tunnel. |
whoops here's the inside picture form the forum , which better shows what I am talking about.
This is the trough but I cant figure out where it goes , is it just sealed with that low point to collect water or does it drain somewhere?
I wonder if a drain plug at that point would be a good thing? _________________ -----Slava Ukraini-----
