belky611 Samba Member
Posted: Sat Jan 21, 2023 1:12 pm Post subject: Auxiliary turn signals for added safety / visibility |
I recently added some comments to this post by FJBen https://www.thesamba.com/vw/forum/viewtopic.php?t=775845 I shared that I had experienced several rear end near misses that I initially put down to inattentive drivers until I realized that the visibility of my turn signals left a lot to be desired - they work but are so small and low mounted compared to modern cars with their high mounted super bright led signals- I realized those drivers probably didn't even notice them, relatively dim and mounted way down by the bumper.
So I resolved to remedy that with some bright LED turn signals mounted high enough to be noticed. I also resolve NOT to drill any holes in the body so I devised a plan to put them inside, mounted on the rear door trim alongside the third brake light (two tiny holes in the plastic trim for each does not bother me - besides I already discovered that ACE hardware brand plumbers epoxy (grey) is a perfect match to my grey interion to plug unwanted hoes and minor repairs (bonus tip there for you)
So here's how I wired up for the lights - I will cover the mounting and home made brackets in a later post, this is a work in progress but I will say I am well pleased with the progress and outcome so far.
As far as I know I can't post videos here (tried and it didn't work) so I'll share this link to my instagram post on the subject for anyone interested in seeing the turn signal in action https://www.instagram.com/p/CnqbBN3hHXX/
KillerGriller Samba Member
Joined: June 15, 2022 Posts: 52 Location: Ontario, Canada
Posted: Thu Jan 26, 2023 8:24 am Post subject: Re: Auxiliary turn signals for added safety / visibility |
Great addition, well done |
IdeaNerd Samba Member
Joined: May 24, 2016 Posts: 597 Location: Central California
Posted: Thu Jan 26, 2023 11:25 am Post subject: Re: Auxiliary turn signals for added safety / visibility |
Nice! Thanks for posting this! |
Posted: Sat Jan 28, 2023 10:06 am Post subject: Re: Auxiliary turn signals for added safety / visibility |
Here's the finished project, (Link below) wires are wrapped identical to the stock 3rd brake light and tucked neatly up to the plastic trim, Mounting brackets made with modeling brass and a little sticky backed foam for anti rattle padding, holding everything firm. When the weather is warmer I plan on priming and paint the the brass brackets / black screws to complete the black on grey blend in.
The clip with the old guy hand blocking the stock signals is intended to simulate a vehicle behind the van blocking the view of the stock signals, as can happen in traffic, as you can see the new led are quite visible in broad daylight.
https://www.instagram.com/p/Cn0fdAJMgvz/ |
