Looking for a pre 2020 2239 cam
Alstrup
Alstrup is offline
PostPosted: Sun Jan 22, 2023 3:47 pm    Post subject: Looking for a pre 2020 2239 cam Reply with quote
Hello.
Maybe not the correct forum to search, but I think here has the most viewers who could happen to have.
As the title says, I am searching for a pre 2020 CB 2239 cam. New or good used.
Price, U tell me.
Please send me a PM or Email.
Thanks much
Torben
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Sun Jan 22, 2023 4:16 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
I think a have a used 2241 and a 2246 somewhere in my mess. I would call the 2241 as being w110ish.
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
jeffrey8164 Premium Member
jeffrey8164 is offline
PostPosted: Sun Jan 22, 2023 6:14 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
Dude Man,
I'm no help either. I have good Erson VW-200 with matching lifters...
Sorry
Volkswagen!
(Compression 8.7:1)
chrisflstf
chrisflstf is offline
PostPosted: Mon Jan 23, 2023 8:44 am    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
I have one of these. What is unique about pre 2020 or post 2020?
Alstrup
Alstrup is offline
PostPosted: Mon Jan 23, 2023 2:21 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
Pm sent.
RickS
RickS is offline
PostPosted: Mon Jan 23, 2023 2:51 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
Alstrup wrote:
Pm sent.
Why are you holding out on the rest of us? Very Happy
Pruneman99
Pruneman99 is offline
PostPosted: Mon Jan 23, 2023 3:02 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
RickS wrote:
Alstrup wrote:
Pm sent.
Now I'm curious as well. I have one as well. Did they make them with a gold core? Laughing
I'm not interested in selling it because it's going in my build when life actually let's me get to it. I've got more money in cam bearings than the cam. Hint* don't use the silverline double thrust bearings..
germansupplyscott
germansupplyscott is offline
PostPosted: Mon Jan 23, 2023 6:51 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
The pre-2020 cam never got COVID
SL
Millionmph
Millionmph is offline
PostPosted: Mon Jan 23, 2023 9:26 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
How come?
Pruneman99
PostPosted: Mon Jan 23, 2023 9:40 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
Millionmph wrote:
How come?
After futzing with multiple sets of the Silverline Double Thrust bearings, I came to the conclusion that each bearing half was like 50.1% of a circle. So when they got torqued in the case, they would go all taco shaped and pinch the cam.
When I had my case worked on, Carcraft ran a cam bearing bar through the case to ensure the cam tunnel was true. They can actually shrink over time. The cutter *just* kissed a few places, so I'm pretty sure the case was true.
Further evidence that the case was fine, and the silverline double thrust bearings were the problem was when I finally got a set of Mahle double thrust. The case went together and the cam spins like glass. The Mahle bearings were noticeably heavier as well.
jpaull
jpaull is offline
PostPosted: Mon Jan 23, 2023 10:15 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
Regarding cam bearings, Mahle Dual Thrust Cam bearings are back in stock now. ($30) No reason to mess with silverline.
https://www.ebay.com/itm/115274591043?hash=item1ad...R5KzjKO8YQ
Alstrup
Alstrup is offline
PostPosted: Tue Jan 24, 2023 10:01 am    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
The pre 2020 version is slightly shorter duration which is good for some of my specific build. The post 2020 version is not a bad cam, at all, in fact I find it quite good, but for a slightly different focus area. If you build your engine well the new 39 is right behind the W110, only with significantly more bottom end and less power above 5300. 110-115 hp is not uncommon in dual carbed 1776 engines with good small valve heads.
When CB gets their cam business up and running again, I hope they raise the price by 5 or 10 bucks and slow down the grinding process so the cams get more precise. Thay helps incredibly much with both power, valve control and running noise.
johnnyvw164
johnnyvw164 is offline
PostPosted: Tue Jan 24, 2023 10:10 am    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
[quote="jpaull"]Regarding cam bearings, Mahle Dual Thrust Cam bearings are back in stock now. ($30) No reason to mess with silverline.
thanks for that link!
vwracerdave
vwracerdave is offline
PostPosted: Tue Jan 24, 2023 10:51 am    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
Maybe their grinding machine and master blanks are old and worn out.
Pruneman99
PostPosted: Wed Feb 01, 2023 10:53 am    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
Alstrup, check your PM.
Cam sent.
jpaull
jpaull is offline
PostPosted: Wed Feb 01, 2023 1:34 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
Cam sent.
Thats very cool of you to speak up, and to help out! You can be sure its for a really good cause!
[email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth.
Alstrup
Alstrup is offline
PostPosted: Wed Feb 01, 2023 4:13 pm    Post subject: Re: Looking for a pre 2020 2239 cam Reply with quote
PM answered.
Thanks mate.
