Brake Upgrade
nax
nax is offline
PostPosted: Wed Jan 25, 2023 7:01 am    Post subject: Brake Upgrade Reply with quote
Hi all!
One of my friends is considering to install 1302/1303 (superbeetle) cylinders and pads in his 65 beetle.
Has anyone done this?
nax
nax is offline
PostPosted: Thu Jan 26, 2023 1:54 pm    Post subject: Re: Brake Upgrade Reply with quote
Nobody? Maybe is not a good idea but the target was to improve the performance…he is telling me that is not plug and play and needs to adapt those components..
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Jan 26, 2023 2:18 pm    Post subject: Re: Brake Upgrade Reply with quote
If I were to make that big a change in front brakes I'd consider a well-made disc brake conversion instead.
mukluk
mukluk is offline
PostPosted: Thu Jan 26, 2023 2:47 pm    Post subject: Re: Brake Upgrade Reply with quote
Super front brakes are both larger in diameter and wider than stock '65 brakes, so the shoes will not physically fit inside wide five drums. Similarly, the wheel cylinders are designed with a different offset from the backing plate to account for the wider shoes.
nax
nax is offline
PostPosted: Fri Jan 27, 2023 4:55 am    Post subject: Re: Brake Upgrade Reply with quote
Thank you!
nax
nax is offline
PostPosted: Fri Jan 27, 2023 4:56 am    Post subject: Re: Brake Upgrade Reply with quote
You are right, here is not easy to legalize that type of changes Confused
