troym99 Samba Member
Joined: December 02, 2022 Posts: 10 Location: Chicago
Posted: Wed Jan 25, 2023 4:06 pm Post subject: Master Cylinder Pushrod |
1963 Beetle Chassis Project came without a pushrod. I purchased one like this.
https://www.mtmfg.com/part/view/brake-master-cylin...rTEALw_wcB
I have a stock master cylinder, but this pushrod is way too short - Even when adjusted to it's max.
What am I doing wrong? Did I buy the wrong rod? |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Wed Jan 25, 2023 4:28 pm Post subject: Re: Master Cylinder Pushrod |
Could be the wrong part, could be your pedal stop needs adjusted. What is the measurement from the top of your brake pedal straight forward to the firewall? How much freeplay are you seeing?
_________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed Jan 25, 2023 7:51 pm Post subject: Re: Master Cylinder Pushrod |
Thank you for that information. That's very helpful. I have the pedal set for 200mm travel, and the pushrod come completely out of the MC even at it's maximum length. It may be the wrong part - but there are lots of sellers advertising these saying they fit my application. I realize they need adjustment, but any idea approximately it should be in a typical setup? |
EVfun Samba Member
Posted: Wed Jan 25, 2023 8:22 pm Post subject: Re: Master Cylinder Pushrod |
That pushrod looks way to short. My beach buggy is an August '63 chassis (so early '64 model year) and my brake pushrod looks like version "A" in this Samba ad. I have used that pushrod with the stock original master cylinder, with a '66 down Bus master cylinder (used to be commonly sold as a buggy master cylinder) and with a late model Bug dual circuit master cylinder (that is what I run now). _________________
Wildthings wrote: |
Posted: Wed Jan 25, 2023 9:20 pm Post subject: Re: Master Cylinder Pushrod |
Thanks EVfun - It is way too short. Max I can get out of it is about 120mm. I don't see how they can be marketing these to fit. I just ordered another one. We'll see if it fits. |
