Question on heads
Bugeye54487
Bugeye54487 is offline
PostPosted: Wed Jan 25, 2023 4:47 pm    Post subject: Question on heads Reply with quote
Have some valve leakage according to leak down test.
1 Can I just clean the valves and lap them to seal?
2 I assume the black is blow by on my bottom head?
What caused it and how to prevent it from doing so.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jan 25, 2023 4:48 pm    Post subject: Re: Question on heads Reply with quote
Mostly likely needs new valves and seats... guides also.
Glenn
Member #1009
#BlueSquare
Pruneman99
Pruneman99 is offline
PostPosted: Wed Jan 25, 2023 4:55 pm    Post subject: Re: Question on heads Reply with quote
Are you sure it's the valves leaking? Sure looks like the it was leaking pretty bad at the cylinder to head.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Wed Jan 25, 2023 6:02 pm    Post subject: Re: Question on heads Reply with quote
Send the heads to Larry in Mi.
I have never had any work done by him yet. But I may need him for some future case/head work.
https://www.thesamba.com/vw/classifieds/detail.php?id=2334287
OP, your heads likely need the valves checked by a pro.
Also the heads likely need fly cutting to get a good seal.
Before I install heads and cylinders. I lap the cylinders to the head. Once the cylinder is lapped. Mark it's specific location that it's lapped to.
This reduces the chance of leaks down the road. Unlike what we are witnessing in the above image.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
