cptcrusty1 Samba Member
Posted: Thu Jan 26, 2023 11:11 am Post subject: EMPI Full Flow Oil Pump with Filter mount - Temp/Pressure hole?? |
On the EMPI Full Flow Oil Pump with the oil filter mount, there is a Black-Allen Head set screw, or similar. It LOOKS like I could pull this out and put an oil temp sensor in there. Has anyone done that or messed with that screw? Anyone know it's purpose?
https://www.amazon.com/EMPI-9207-7-Full-Flow-Filte...9084116476 |
Posted: Mon Jan 30, 2023 9:00 pm Post subject: Re: EMPI Full Flow Oil Pump with Filter mount - Temp/Pressure hole?? |
Bueller? |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Mon Jan 30, 2023 10:31 pm Post subject: Re: EMPI Full Flow Oil Pump with Filter mount - Temp/Pressure hole?? |
That'ss a pressure relief bypass. If the filter is very clogged or the oil overly thick (cold weather) and has really high pressure on the INLET side of the filter, pressure can push this check valve open and some oil bypass the filter.
This is NOT a place to install a temp sensor. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Posted: Wed Feb 01, 2023 5:52 am Post subject: Re: EMPI Full Flow Oil Pump with Filter mount - Temp/Pressure hole?? |
Lo Cash John wrote: |
This is NOT a place to install a temp sensor. |
As Jim Carey would say... "Well... OK, THEN!"
Thanks for the info. I have now stopped my self from pulling out the high impact allen heads and ripping it out |
