cdussault Samba Member
Posted: Thu Jan 26, 2023 7:42 pm Post subject: Driving light preferences |
Hey there - looking for opinions -
Round or square look driving lights?
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76947 Location: Sneaking up behind you
Posted: Thu Jan 26, 2023 7:44 pm Post subject: Re: Driving light preferences |
Round _________________ Glenn
Member #1009
#BlueSquare |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 952 Location: Northern California
Posted: Thu Jan 26, 2023 8:24 pm Post subject: Re: Driving light preferences |
Round if you imagine yourself driving the Baja 500, rectangle if you have any sense of design. Amber lens is usually for fog lights, white for driving lights… _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
Abscate Samba Member
Posted: Fri Jan 27, 2023 12:44 am Post subject: Re: Driving light preferences |
Make a few more passes with the blue sharpie…. _________________ .ssS! |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1477 Location: Westfield, MA.
Posted: Fri Jan 27, 2023 4:22 am Post subject: Re: Driving light preferences |
I'll be running those exact rectangle units on my '83. They're almost exactly what VW had as an optional accessory. I bought a set of the Brickwerks repro brackets and they are NICE! |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Fri Jan 27, 2023 4:41 am Post subject: Re: Driving light preferences |
IMO square with square looks better.
However most probably the round has better light projection
_________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
4Gears4Tires Samba Member
Posted: Fri Jan 27, 2023 6:24 am Post subject: Re: Driving light preferences |
Round.
Square foglights only if they are recessed. _________________ '87 Syncro
DuncanS Samba Member
Posted: Fri Jan 27, 2023 6:34 am Post subject: Re: Driving light preferences |
There is a bunch of crash important structural steel from under the rectangular outer headlight down to the bumper, so a light could only be recessed if located directly under the square high beam. On the DS there is some stuff which prevents direct observation of recess possibility there. It may be possible, but I haven't explored enough to know for sure.
Duncan |
Kdj Samba Member
Joined: January 28, 2017 Posts: 142 Location: Naptown
Posted: Fri Jan 27, 2023 9:53 am Post subject: Re: Driving light preferences |
Square if your keeping stock headlights. I think its better aesthetically. Light out put might be better with round depending on brand of light! Mine's an 82 so I prefer round personally |
69aircooled Samba Member
Joined: August 04, 2004 Posts: 241 Location: North Carolina
Posted: Fri Jan 27, 2023 10:11 am Post subject: Re: Driving light preferences |
I'd go square with square and round with round, but definitely a little zinc with flat tappets |
JonnyB32 Samba Member
Joined: August 24, 2022 Posts: 5 Location: Stoke-on-Trent ,England
Posted: Fri Jan 27, 2023 10:47 am Post subject: Re: Driving light preferences |
Projekt zwo lights rectangle is ok ,but round spots with square headlight just check what 80s cars ran with ford escort and granada all had round with square headlights,your preference though!! I'll be getting round for my square headlight bus ,whatever still a cool ride. |
Posted: Fri Jan 27, 2023 11:37 am Post subject: Re: Driving light preferences |
If you are adding “driving” lights (narrow beam illuminating the road 100 meters ahead), then the above-bumper location you show is preferred. If mounting “fog” lights (wide dispersed beam with sharp upper cutoff), then you may wish to consider a below-bumper location.
Tornado Red |
jlrftype7 Samba Member
Posted: Fri Jan 27, 2023 11:47 am Post subject: Re: Driving light preferences |
No problem with a mix and match here. Fog Lights went where the RMW mounts already fit them. But, the lower an Auxiliary Light is mounted, the more I’ve lost a lens on one in the past when using them. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Crankey Samba Member
Posted: Fri Jan 27, 2023 12:44 pm Post subject: Re: Driving light preferences |
For lights mounted down on the bumper I'd go rectangular just because everything else down there is rectangular. |
Timwhy Samba Member
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 785 Location: WestWorld Nanaimo BC
Posted: Fri Jan 27, 2023 1:39 pm Post subject: Re: Driving light preferences |
Round...but they need to be bigger
Out of the sets you have I prefer the squares _________________ 1991 Double door pop top conversion |
Glenn Mr. 010
Posted: Fri Jan 27, 2023 1:43 pm Post subject: Re: Driving light preferences |
RoryGirl wrote: |
Out of the sets you have I prefer the squares |
Over compensating? _________________ Glenn
Member #1009
#BlueSquare |
