Tweeds coombo spindle FYI.
77charger
77charger is offline
PostPosted: Thu Jan 26, 2023 8:33 pm    Post subject: Tweeds coombo spindle FYI. Reply with quote
I have had the newer needle bearing ones since 2010-11 or so but had to replace link pin bushing and know they are non existent unless custom made.
My machinist looked at them told me its a standard king pin and a foddril will work.My king pins were worn so bought 2 foddril king pins yup fit right on.You will have to adjust and move the washers but no big deal forgot which go where and use the foddril snaprings.
I know some still run them so figure id throw it out there for those who were wondering.
Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sat Jan 28, 2023 12:35 pm    Post subject: Re: Tweeds coombo spindle FYI. Reply with quote
Good information for those using Tweeds Combos.
Thanks for posting.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
77charger
PostPosted: Sat Jan 28, 2023 5:40 pm    Post subject: Re: Tweeds coombo spindle FYI. Reply with quote
Thanks for posting.
Exactly and why i posted it i know many here ran them and at one pint looking for link pin bushings.By now king pins may be worn out too so perfect time to swap and rebuild them and now you have a common link pin bushing.
The needle bearings are the same as foddril ones too.I spent about 330 in parts but rather do this than go with the china spindles.
Click to view image
2275 built by me
