AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 561 Location: Triad Area NC
Posted: Fri Jan 27, 2023 11:29 am Post subject: Hypothetical Universal Gauge |
If you had a universal gauge that displayed multiple things in your ordinary, road driven (not track) ACVW, what information would you find useful for everyday driving?
Some ideas are below, what else would you add?
1. Current speed
2. Direction of travel
3. Current time
4. Engine RPM
5. Outside temperature
6. Fuel level
7. Oil temperature
8. Temperature near the thermostat
What else?
anthax Samba Member
Joined: October 21, 2016 Posts: 280 Location: Hälsingland, Sweden
Posted: Fri Jan 27, 2023 11:43 am Post subject: Re: Hypothetical Universal Gauge |
Speed, rpm, oil temp, fuel gauge. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3475 Location: viroqua wi.
Posted: Fri Jan 27, 2023 1:05 pm Post subject: Re: Hypothetical Universal Gauge |
anthax wrote: |
Speed, Head temp, Fuel gauge, Oil pressure. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Jan 27, 2023 2:16 pm Post subject: Re: Hypothetical Universal Gauge |
Voltage, gotta know if the belt is on. |
Posted: Fri Jan 27, 2023 2:31 pm Post subject: Re: Hypothetical Universal Gauge |
ps2375 wrote: |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3804 Location: Georgia
Posted: Fri Jan 27, 2023 5:40 pm Post subject: Re: Hypothetical Universal Gauge |
I have a PLX multi gauge setup.
https://www.plxdevices.com/PLX-MultiGauges-and-Sensors-s/108.htm
Currently monitoring oil pressure and temperature, cylinder head temperature, AFR and RPM. I have their touchscreen gauge and the Bluetooth module to display on my phone.
They have sensors for a lot more things than I need.
It’s not all displayed at once on the gauge but it is on my phone. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Fri Jan 27, 2023 5:41 pm Post subject: Re: Hypothetical Universal Gauge |
Wish I could read German. _________________ Volkswagen!
SGKent Samba Member
Posted: Fri Jan 27, 2023 6:57 pm Post subject: Re: Hypothetical Universal Gauge |
too much information in a small space. I want what I have. I can look at whatever I want to know. My head is out there in front and around the car, not stuck in my dash. I also train my co-pilot what is normal and if they see something odd they can mention it.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jan 27, 2023 7:27 pm Post subject: Re: Hypothetical Universal Gauge |
It is a lot of extraneous information.
For all the money I spent on it the only gauges I really look at are the gas gauge and the speedometer.
The AFR was useful in tuning though. _________________ Volkswagen!
94touring Samba Member
Joined: October 24, 2020 Posts: 290 Location: Oklahoma - OK
Posted: Fri Jan 27, 2023 7:48 pm Post subject: Re: Hypothetical Universal Gauge |
Tach, cylinder head temp, and oil temp gauge. I did leave my wideband installed, which helped diagnose a clogged fuel filter once on the limp back to the shop. I have a usb cigarette adapter with a voltage readout for belt mishaps and load on my power inverter when running my camp fridge or anything else while driving. I finally converted to a gps speedo to rid notchy cables. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Fri Jan 27, 2023 8:05 pm Post subject: Re: Hypothetical Universal Gauge |
Speed and gas.... what the factory knew you needed.
But some will disagree.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Jan 27, 2023 8:33 pm Post subject: Re: Hypothetical Universal Gauge |
There is no substitute for insanity. _________________ Volkswagen!
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2714 Location: Hamble, Hampshire, UK
Posted: Sat Jan 28, 2023 2:44 am Post subject: Re: Hypothetical Universal Gauge |
CHT and oil pressure on a long run.
AFR and CHT on a short run.
Plus oil temperature on a separate VDO gauge.
My setup is based on a PLX system but the MFD got fried when 12 volts got into the PLX wiring.. ( engine bay fire )
So this is my own MFDs.
_________________ Ancient vehicles and vessels
madmike Samba Member
Joined: July 11, 2005 Posts: 5291 Location: Atlanta,Michigan
Posted: Sat Jan 28, 2023 5:48 am Post subject: Re: Hypothetical Universal Gauge |
PLX is on the far right,That thing does everything I have all Autometer gauges ,still lookin for a free CHT gauge It's the only one I'm missing Cheers,MIke _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8689 Location: Sunset, Louisiana
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9664 Location: Oregon
Posted: Sat Jan 28, 2023 10:47 am Post subject: Re: Hypothetical Universal Gauge |
UK Luke 72 wrote: |
jeffrey8164 wrote: |
Wish I could read German. |
Does your browser not auto translate?
I have oil temp/pressure. CHT and AFR
Only really look at AFR and oil pressure though. |
That's a nice bit of kit!
I wonder if you can order one without the fuel gauge feature?
Mine being a 67, has the dash mounted fuel gauge. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Jan 28, 2023 4:17 pm Post subject: Re: Hypothetical Universal Gauge |
UK Luke 72 wrote: |
I suppose it does if pay attention to the pop out.
Looks cool but I'm in a Ghia with a separate fuel gauge so I don't have a donor to modify. I suppose I could buy one but then I'd have to redo my dash to close up some holes. _________________ Volkswagen!
Posted: Sat Jan 28, 2023 4:30 pm Post subject: Re: Hypothetical Universal Gauge |
I want an audible for oil pressure and on a Type 1 voltage. |
