classicbug Samba Member
Posted: Sat Jan 28, 2023 12:26 pm Post subject: Suspension rubber thingy |
I check my John Muir bible and wasn't able to locate this part.
Clearly it needs to be replaced, but, I don't know what purpose it serves.
Can someone help me out?
Slow-N-Rusty Samba Member
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Sat Jan 28, 2023 2:03 pm Post subject: Re: Suspension rubber thingy |
Bump stop.
You might look into my rather bad experience with a name brand aftermarket many years ago:
glutamodo wrote: |
It's a bump stop. VW called them "Stop (Rubber) Torsion Arm" in the parts book.
Oh, and unless WW has improved their brand with a better grade of rubber, I'd avoid theirs. Here's what my WW "snubbers" looked when I took them off after about 16 months of service.
_________________ Andy T.
Posted: Sat Jan 28, 2023 2:14 pm Post subject: Re: Suspension rubber thingy |
Thanks, I'll order a new set. Hopefully not too difficult to install. |
glutamodo wrote: |
Bump stop.
glutamodo wrote: |
Thanks, I'll order a new set. Hopefully not too difficult to install. Did you end up finding a better quality product? If so, where? |
carcrazed Samba Member
Posted: Sat Jan 28, 2023 5:10 pm Post subject: Re: Suspension rubber thingy |
Make sure you them real warm so they are softer and put some lubricant inside. Take a mallet and tap them on...done. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
Posted: Sat Jan 28, 2023 8:16 pm Post subject: Re: Suspension rubber thingy |
Which is what I did. But then just a few months of driving and they were done-in!
As for the question if I found a better option, this was like, 10 years ago , but yes i did. Can not remember the brand name for sure (maybe Vibrasil ) but they were out of Brazil and they are fine. I've posted on the topic before: https://www.thesamba.com/vw/forum/viewtopic.php?t=592751& _________________ Andy T.
Zundfolge1432 Samba Member
Posted: Sun Jan 29, 2023 6:43 am Post subject: Re: Suspension rubber thingy |
carcrazed wrote: |
Make sure you them real warm so they are softer and put some lubricant inside. Take a mallet and tap them on...done. |
The choice of lubricant may be part of the problem. Petroleum products will degrade rubber. I’d try a mild dish detergent or maybe talcum powder, but if you use talcum powder make sure it’s asbestos free. Silicone spray also a possibility but I like the dish soap cause it’s cheap and readily available 😀 |
