motomwo Samba Member
Joined: February 10, 2017 Posts: 263 Location: Oregon
Posted: Sat Jan 28, 2023 2:16 pm Post subject: alternator shaft length question, fan end |
I went to assemble my new alternator to the backing plate and fan and the oem nut only has 3 threads engagement on the shaft after spacing the fan out from the backing plate the correct distance, about 1.8-2.0mm. measuring from the shaft spacer collar to the shaft end I get about 30mm shaft length. Is the correct length or should it be longer? I never ran into this problem before. The fan is a new Berg item for the dog house shroud and the alternator is EMPI 00-9445-7.
Any ideas? Anyone got a shaft length measurement?
Thanks, Marty
_________________ 1961 Bug, 2276 cb wedge ports 44x37 11.1 comp fk10 1.5 rockers 48idf's 1 3/4" header Rancho pro street trans SAW axles Airkewld 4# narrowed beam, Koni shocks, Airkewld dis brake all around. 5.5/4.5 BRMs
1966 Bug, 2127, panchito heads, fk8, 1.3 rockers, dual 44idfs, 1 5/8 merge header, Rancho pro strt flyer, empi axles, Airkewld's 4" beam and discs all around and adjustable shocks. 4.5 & 5.5 BRMs |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Sat Jan 28, 2023 4:25 pm Post subject: Re: alternator shaft length question, fan end |
Wish I could help. Mine is currently installed. I bought a Compufire 90 amp alternator from CIP1.
It fit perfectly with my stock doghouse fan. The supposedly balanced and welded fan I also bought from CIP1 was neither square nor round and the dish was wrong. Needless to say, that got returned. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Sat Jan 28, 2023 5:13 pm Post subject: Re: alternator shaft length question, fan end |
jeffrey8164 wrote: |
It fit perfectly with my stock doghouse fan. The supposedly balanced and welded fan I also bought from CIP1 was neither square nor round and the dish was wrong. Needless to say, that got returned. |
Thank you for the info. I hope my Berg fan has the correct dish. I don't have another fan or alternator to compare measurements as the ones I have are also installed.
Any more seems we have to suspect every part and supplier. Hopefully someone can provide measurements of the shaft length and the fan dish would be helpful.
Marty _________________ 1961 Bug, 2276 cb wedge ports 44x37 11.1 comp fk10 1.5 rockers 48idf's 1 3/4" header Rancho pro street trans SAW axles Airkewld 4# narrowed beam, Koni shocks, Airkewld dis brake all around. 5.5/4.5 BRMs
allamaabroad Samba Member
Joined: September 22, 2016 Posts: 560 Location: South Jordan, Utah
Posted: Sat Jan 28, 2023 5:22 pm Post subject: Re: alternator shaft length question, fan end |
motomwo wrote: |
Thanks, Marty
That shaft length looks about right, doesn't look obviously wrong to me.
How many shims did you have to use to keep it from rubbing? I'd say if you're having to use more than 3 or so, there's something jacked up with either the backing plate or the fan that you're using. _________________ Dennis - 1973 Super Beetle ('16-'21)
Debbie- 1970 Baywindow Bus ('21 - Present)
Tin top camper/adventure bus
2180 TW: CNC Panchitos, Beehives Done Right, Web 163, Ultralight Lifters, 1.3 Rockers, CSP Python, Custom Speeduino EFI Conversion with 40mm Throttle Bodies
Distributors are lame
I have a really hard time leaving things alone...
Innovative and affordable engine management systems and EFI conversions for your Vintage VW
Visit https://debbiesaircooled.com/ |
yinnawagon Samba Member
Posted: Sun Jan 29, 2023 12:40 am Post subject: Re: alternator shaft length question, fan end |
Bosch generator = 35.03mm
chineesium alt = 30.88 mm |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Jan 29, 2023 5:27 am Post subject: Re: alternator shaft length question, fan end |
Damn, 5mm what's the pulley end? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Sun Jan 29, 2023 7:46 am Post subject: Re: alternator shaft length question, fan end |
yinnawagon wrote: |
That is what I figured the measurement differences would be. That extra 5mm is the distance I need to make it correct. If I use this Chinese alternator I would have to use so many shims that the hub would barely engage with the hub flats on the fan. And only have 3 full threads engagement into the shaft nut. So I will be sending the alternator back.
Another question I have is what is the back spacing or dish on the oem fan? I have a new Berg welded and balance fan and want to compare it with the oem fan.
Thank you for the help!
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3900 Location: Seattle, WA
Posted: Sun Jan 29, 2023 7:46 pm Post subject: Re: alternator shaft length question, fan end |
I have an older Bosch AL82 on hand, the shaft measurement as shown above is 30.0 mm. This alt has been installed and works fine with stock parts. It seems the shaft length is not your problem.
Did you torque the fan nut? If not, it will go on quite a few threads more when the bent lock washer is compressed flat. _________________ '67 bug: seized by the authorities
Posted: Sun Jan 29, 2023 8:37 pm Post subject: Re: alternator shaft length question, fan end |
kreemoweet wrote: |
Did you torque the fan nut? If not, it will go on quite a few threads more when the bent lock washer is compressed flat. |
Thank you for replying. Yes I did torque the nut down. I am beginning to think the Berg fan may have to much dish or back spacing. It has 15mm back spacing.
Hoping someone can measure the back spacing on their oem dog house style fan and post what the measurement is.
Posted: Mon Jan 30, 2023 10:32 am Post subject: Re: alternator shaft length question, fan end |
Can someone please measure the back spacing or "dish" on their oem dog house style fan and post what the measurement is. The side that faces the alternator or backing plate. This would be a big help trying to solve this problem.
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Mon Jan 30, 2023 6:23 pm Post subject: Re: alternator shaft length question, fan end |
i get about .495 ( didnt have my glasses on ) |
Posted: Mon Jan 30, 2023 6:41 pm Post subject: Re: alternator shaft length question, fan end |
chrisflstf wrote: |
Thank you, that is about 12.5mm. Thank you very much for the response.
Talked to a friend today on the phone and he got the same measurement on his oem fan. So that is 2.5mm difference in backspacing compared to my recently purchased Berg welded fan. I will be shipping the fan back to Gene Berg. The 2.5 mm difference adds up to all the extra shims I have to use to get the fan to backing plate clearance spec correct.
