Red The Grey Samba Member
Posted: Sat Jan 28, 2023 10:11 pm Post subject: cooler shroud shutter flap arm |
I want to make my shutter flap setup work... right now I have a earlier setup and want to run the doghouse fan shroud so do I have to get the proper arm so it will clear the doghouse extra cooler setup so the shutters wont hangup ??? Does anyone have pictures so I will know what to look for???
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat Jan 28, 2023 10:27 pm Post subject: Re: cooler shroud shutter flap arm |
That was hard to read.
Your answer is Yes. The crossbar has a bend to clear the oil cooler projection. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jan 29, 2023 1:05 pm Post subject: Re: cooler shroud shutter flap arm |
VW Jimbo I fixed it so its readable now thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Sun Jan 29, 2023 1:39 pm Post subject: Re: cooler shroud shutter flap arm |
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Feb 03, 2023 8:22 pm Post subject: Re: cooler shroud shutter flap arm |
I'm not planning to use my heaters just the J pipes I can use a 12 volt setup that works better but I saw that my flap setup might not work that well unless I use a tin setup like that awesome powdercoat industrial shields has to offer but are they really necessary especially on the other side where the bellows isnt there any suggestions??? |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Fri Feb 03, 2023 10:24 pm Post subject: Re: cooler shroud shutter flap arm |
Some members here have made their own industrial tins. Maybe search heater box delete tins. Or some combination.
But yes, you will need them if you are running J pipes in place of the heater boxes. |
Glenn Mr. 010
Posted: Sat Feb 04, 2023 6:16 am Post subject: Re: cooler shroud shutter flap arm |
Genuine Type 181 tins.
Member #1009
#BlueSquare |
