minirailz Samba Member
Posted: Sun Jan 29, 2023 11:42 am Post subject: Puzzled by main bearing issue |
Hi!
By the end of last summer I decided to rebuild an engine, for the learning proces and also to have a spare on the shelf.
I try to do it by the book, replace or refurbish, depending on the state of the materials.
I'm doing a mostly stock 1300 F-block.
I send my case over to Germany to get it alignbored by Ahnendorp, an aircooled engine rebuilding specialist.
They decided to bore the case to +1.00, thrustbearing -1.00 (21mm), the new CSP crank was balanced and kept it's STD measurements.
Bearings were supplied by Ahnendorp and are silverline.
When installing the main bearings, the thrustbearing at the flywheel is a really tight fit.
When closing the case, using the 6 M12 bolts, the crank binds to the case.
The bearings are not pinched or blocked by the dowel pins...
(because I already pinched my first set, so learned that the hard way )
I did try without the pins, but no difference.
When using the trick to set the other half of the splitted main bearing on the crank, while installed in one case half, it has about 0,7mm of slack.
Way too much. There's no slack without the last bearing installed.
So it seems that the thrustbearing is not aligned with the other bearings.
Question now is: how do I proceed, what can I still test to confirm or fix this?
Could it be a warped case or would that have been noticed during alignboring?
Any advice much appreciated!!
Thanks!
Dennis
ps: sending the case back to Ahnendorp is a costly business, so I can't just jump in and ask them to take a look. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Sun Jan 29, 2023 1:50 pm Post subject: Re: Puzzled by main bearing issue |
minirailz wrote: |
With the other half of the splitted main bearing on the crank, while installed in one case half, it has about 0,7mm of slack.
Thanks!
Dennis
Just worked on a engine that the customer built the short block and the crank was locked.
Same.... with just the 6 main bolts it was locked. No marks on the bearings. Machine shop confirmed that the bearings saddles were not straight.
Case is trash. _________________ Glenn
Member #1009
#BlueSquare |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sun Jan 29, 2023 2:55 pm Post subject: Re: Puzzled by main bearing issue |
I can talk about it all day, literally, but it's up to you to decide what to do about it.
This is in response to many similar questions over the years.
https://www.thesamba.com/vw/forum/viewtopic.php?t=777121 |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Sun Jan 29, 2023 3:03 pm Post subject: Re: Puzzled by main bearing issue |
Have you checked the crank to see if it's bent? _________________ 1960 Ragtop w/Semaphores "Inga" |
SGKent Samba Member
Posted: Sun Jan 29, 2023 3:13 pm Post subject: Re: Puzzled by main bearing issue |
It must spin freely using something like SAE30. Use a plastic mallet or something to tap the bearings into the case. Were it me at this point I would have the crank gear off to make it easy, then try it with #2 and #3 main. See if it spins freely or not. If not try #2 and #4. If it does then you know it is #3. Try to see if they are all tight or just one. It sounds like someone screwed up either doing the cutting, or with the bearing set. You can also spin it with the bearings in one case half to see how it feels. It could be as simple as they sent the wrong bearings. On the back of the bearings there should be marks that show what size they are. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
modok Samba Member
Posted: Sun Jan 29, 2023 6:14 pm Post subject: Re: Puzzled by main bearing issue |
Some people believe the thrust bearing should be a near zero fit in the case front to back.
I don't agree, but it can be done and work fine IF done right.
To make it a tight fit and still work you will probably need to freshly machine both sides to below a half thou runout, which is not easy and not typical.
I commonly find several thou runout on the thrust faces most engine blocks, including these old VWs, and the bearings are similar.
I think the reason some people THINK it needs to be a tight fit is because they don't actually check anything or have no way to check it except by feel and it feels tight to them.
Not saying this is the problem, but may help explain whatever you find if you measure the thrust width of the engine case all the way around, which you might do based on what you said so far. |
modok Samba Member
Posted: Sun Jan 29, 2023 6:36 pm Post subject: Re: Puzzled by main bearing issue |
I prefer to first bolt the housing together and check the size of the bores, BEFORE checking the alignment of the bores.
This lets you check all the way around AND tell if deviations from straight is difference in size VS alignment.
Would be rare to have an alignment problem on a freshly lined bored case, check the sizes and bearings first.
Checking the squareness of the thrust surface is rather difficult and I don't have a easy way to do that. It can be done lots of ways but you should never need to do that. Probably set it up in the machine you'd use to fix it and just check it that way, because then it could be corrected if it's too far off. |
Posted: Sun Jan 29, 2023 11:23 pm Post subject: Re: Puzzled by main bearing issue |
Thank you all for the replies.
I think the crank is straight.
When not bolted down it does turn quite alright, without any differences in resistance.
The thrustbearing shows wear on the bottom left and top right of the inside.
Confirming that the crank is in on an angle.
It did a little math, it seems the crank is 0,1mm higher in the split-bearing if the thrustbearing is mounted. So that last bearing is probably 0,15mm too high/out of round...
Since this is my first build and I asked an aircooled specialist to do the machining, I didn't bought a micrometer to measure the inside of the bores.
I was expecting them to do a good job and/or let me know if it was off.
I might have to acquire such micrometer now I guess...
If the case is warped, would that be my responsibility or would that have shown during the alignbore-process?
I checked the webbing inside and no light comes through...
Dennis |
modok Samba Member
Posted: Sun Jan 29, 2023 11:54 pm Post subject: Re: Puzzled by main bearing issue |
I don't think you fully understood what I have said so far about the squareness of the thrust faces, but....if you want to keep going....
Try it with just #1 and #3 bearings, & check the bearing thickness and housing sizes (aka case holes)
the #1 has to be aligned to the main seal and the transmission centering ring, so that would be how you check it's alignment.
#2 just needs to be-in line with the bearings on either side, which you can check with a straightedge in the bores.
So IF the crank spins with just #3 and #1, then put an indicator on the crank and indicate the bellhousing surface and main seal bore, if you want to see if #1 is in the right spot or not. Perhaps check the gap around the pulley seal bore to see if that is centered also. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Jan 30, 2023 5:31 am Post subject: Re: Puzzled by main bearing issue |
Also, since it’s your first engine build…#1 bearing is the thrust bearing…#4 is by pulley.
Just want to make sure you know
Also, at what torque does it bind? You should check at each interval 10, 15, 20, 25 |
Posted: Mon Jan 30, 2023 5:53 am Post subject: Re: Puzzled by main bearing issue |
OK understood, it's the #1 that is causing me trouble, I think.
I haven't checked yet at what torque it binds. It just get's tougher and tougher I guess. It still sort of moves when it's almost torqued down...
@modok: thank you for the extra information.
I will visit a local engine builder next wednesday, I feel I need some physical advice/help.
Also he has plenty of tools I don' t have to measure or correct the cut, as far as possible of course.
Since I assembled the cam gears, I'm currently unable to remove the #3 bearing.
I tried it before without the #2 bearing, that gave the same result as with all the bearings mounted.
I only feel it's seating properly without #1 and it also turns very smooth in that setup...
I will keep you posted on any progress!!
Dennis
ps: results are same in both case-halves |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 572 Location: South of Raleigh
Posted: Mon Jan 30, 2023 9:36 am Post subject: Re: Puzzled by main bearing issue |
In the "Bergman Bomb" thread an issue came up where the #1 crank journal had a very slight taper towards the end opposite the flywheel...might want to check that, just in case. |
Dusty1 Samba Member
Posted: Mon Jan 30, 2023 9:38 am Post subject: Re: Puzzled by main bearing issue |
minirailz wrote: |
... When installing the main bearings, the thrustbearing at the flywheel is a really tight fit.
I did try without the pins, but no difference.... |
I had a "new" Mexican case with a slightly surface rusted crank and rusty rods stickin' out. I got it "locked up", it wouldn't turn. After years in storage I tore it down and found a bearing pinched by the pin.
It took a line bore to clean that up. Seems that if you torque the case without the bearing pins lined up, you warp the case.
With the sad and perhaps untimely demise of Rimco and / or Brothers I'm skeptical of line bored cases. I'm beating the bushes to buy my own line bore tool. It seems I'm at least 20 years too late. I'm not so sure I want to spend thousands of dollars on a tool that's thousands of miles away.
Rimco was great because they didn't have to rely on half a dozen jobbers. Or they were great until they had to rely on half a dozen jobbers.
Every time I get a line on a shop that "does reliable line bores" I subsequently hear horror stories from other rebuilders. Seems to me if I'm getting a line bore done I should send the machinist my case and my crank, maybe main bearings as well. I think it would be value- added to get my parts back assembled as a "short block" with a balanced reciprocating assembly and proper bearing clearance and end play.
I'm thinkin' that rather than spending thousands on an old Porta Tool perhaps I should tap my genius machinist buddy to create reliable and repeatable line boring tooling for an old Cincinnati horizonal mill or something.
As far as ROI (Return On Investment) goes how many $500 cases do I need to sacrifice to $100 line bores?
Posted: Tue Jan 31, 2023 3:15 am Post subject: Re: Puzzled by main bearing issue |
The above is very true.
IF I warped the case, or it was warped before, I will definitely ask for a new linebored case.
I want a fully assembled short block, it's just a pain and costly affair if you're like me and having not enough experience to get it right...
Dennis |
Posted: Wed Feb 01, 2023 6:14 am Post subject: Re: Puzzled by main bearing issue |
Ok, so I went to a local VWAC engine builder to have my case checked.
(I wish I knew him before I went to the German firm)
It appears the line-bore on the #2 was not done exactly straight.
He made a bit more room on #2 and made sure the #1 bearing fitted correctly by machining a little bit off.
Apparently this firm I choose to have it alignbored is known for doing it in 2 stages. 1 or 2 bearings from one end and then they flip the case and do the other side.
Not sure how much of this is true, but it would explain the minor offset.
Afterwards we closed (and sealed) the case together so I can continue my build.
Bottomline:
1. If you go to a aircooled specialist, for premium engine works at a premium price, that's no guarantee it is indeed as good as advertised.
Nevertheless I believe that they still provide good end-products...
2. Rebuilding an engine is fun, but the case/bearing/crank alignment is so critical, it might be worth letting a pro do this particular work.
Thank you all for your advise and wisdom.
Wish me luck on the oncoming challenges
Dennis |
nsracing Samba Member
Posted: Wed Feb 01, 2023 7:26 am Post subject: Re: Puzzled by main bearing issue |
did you check the bearing crush? Use a dialbore gauge and see how much crush on the bearings.
Not all linebore jobs are created equal. You get what you pay for - |
Posted: Wed Feb 01, 2023 8:21 am Post subject: Re: Puzzled by main bearing issue |
The crush was not measured unfortunately.
I guess this only applies on the split bearing?
I payed top-dollar (top-euro?) for a linebore by an experienced well-known ACVW/Porsche tuning company.
I guess they just blindly bored and returned the case.
If you buy a full engine, they figure out themselves it needs more machining I hope...
Dennis |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Wed Feb 01, 2023 9:32 am Post subject: Re: Puzzled by main bearing issue |
minirailz wrote: |
Dennis |
You got it right.
In all fairness, there's so much variation in bearings (and cranks) now,
That all numbers have to be checked, and likely adjusted.
In the old days the bearings were so accurate,
That a case and crank you bought would be a standard size,
And bearings just fit.
No longer. _________________ Bus Motor Build
What’s That Noise?!? |
