Would you use panel bond? |
Yes |
78% |
[ 11 ] |
No |
21% |
[ 3 ] |
Total Votes : 14 |
Vangabonders Samba Member
Joined: January 15, 2013 Posts: 174 Location: Chattanooga TN
Posted: Sun Jan 29, 2023 4:02 pm Post subject: Using panel bonding adhesive for inner nose valence repair |
Haven't seen anyone doing their inner nose repair like this on here and just wanted y'alls thoughts on it. Especially Skillz
_________________ 73 tintop to poptop westfalia (Frankenbus) |
SGKent Samba Member
Posted: Sun Jan 29, 2023 4:52 pm Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
one of the panels on my bus was tacked in place then finished with some 3m stuff. I wasn't happy with the idea until I researched it and found it is used in many cars today. it will be harder to remove than spot welds - but the surfaces have to be prepped right. You won't get two chances. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon Jan 30, 2023 10:40 am Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
prepped right, and the metal will fail before the adhesive will.
edit-Hey! SGKent got a shout out in the youtube vid. you are such a helpful guy. thanks for passing it along. |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2538 Location: Plattsburgh, New York
Posted: Mon Jan 30, 2023 10:48 am Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
I made my own patch panels and did this the hard way. The easiest part of the whole thing was welding the thin piece to the thick section under it with big fat plug welds. That is about the only part of it where I would consider panel bond. |
Posted: Mon Jan 30, 2023 11:26 am Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
alman72 wrote: |
That's my hope! I don't see why the adhesive would fail in this situation. Also SGKent and everyone on this forum have been super helpful. _________________ 73 tintop to poptop westfalia (Frankenbus) |
metahacker Samba Member
Posted: Mon Jan 30, 2023 12:16 pm Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
alman72 wrote: |
prepped right, and the metal will fail before the adhesive will |
i'm pretty sure Lord Fusor (e.g. sales reps) would show shops some demo of their product vs a full weld where they pulled the two apart on a machine and showed how the material itself failed before the adhesive did.
as weird as it might seem to glue stuff together instead of weld, it should actually be better than a weld... if done properly
i had the pleasure of hanging out with the Polestar (volvo innovation subsidiary) design/engineering team recently .. and they were super excited about the extensive use of aluminum extrusions and adhesives throughout a lot of stuff they were working on .. and felt it was better than welding in many applications since you could also apply it in areas that would not be physically accessible to weld .. those guys know what they are doing and aren't afraid of new unconventional approaches ..
but, it does require a little bit of a leap of faith to glue a car together. it's common practice now... e.g. bmw ... also commercial truck bodies have been using it in lieu of welding/fasteners.
the technology is there. |
j10nbom Samba Member
Joined: February 14, 2007 Posts: 262 Location: Philly
Posted: Mon Jan 30, 2023 12:37 pm Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
I used it to patch the floors in my bus years ago and have had zero issues with it. |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Tue Jan 31, 2023 10:21 am Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
I've used fusor panel adhesive on a number of projects. I did some test pcs that impressed me. 1x1 square steel tube glued to to another pc at a 90 degree. 1 inch square glue surface area. Clamped one side in a vise, the other was about a foot long. Couldn't break it by hand. After a bunch of blows with a 5 lb hammer finally broke it free after it bent quite a ways. I made a very large brushed stainless valance over a cooking range that was a tube steel framework with a stainless sheet glued to it, benefit was no weld distortions, no fasteners, attaching dissimilar metals. On our vans a benefit is a waterproof seam. I'd say go for it. |
Vanagonsgoslow Samba Member
Joined: April 18, 2019 Posts: 82 Location: E Dorado Hills, CA
Posted: Tue Jan 31, 2023 11:37 am Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
Look at the video on the MunroLive YouTube channel where they take apart either a new Rivian or new Tesla that had its body put together with panel adhesive. They could not separate the panels at the seams! |
Posted: Tue Jan 31, 2023 2:51 pm Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
i wonder if local FLAPS has the dispense gun on the loan a tool program? I would hate to buy that thing just to sit in the garage untouched ever again. maybe a used ebay purchase. |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
67ctbug Samba Member
Posted: Tue Jan 31, 2023 4:04 pm Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
Globespotter wrote: |
I am planning to use this to patch a hole in the floor of a car I have, and I'm not sure if I should apply it to bare metal, prime, or POR-15 the metal first.
I'm thinking it would stick better to bare metal, but I want to reduce the risk of rust in future.
Thoughts? |
Data sheets, data sheets, data sheets.
Bare metal, 36 grit scratch from a roloc disc. Just remember, these cars weren't meant to be put together with bonding adhesive like new cars and it DOES have its weaknesses. In a perfect world you could use both. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Tue Jan 31, 2023 10:15 pm Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
pandamanda22 wrote: |
Especially Skillz
Don't people read the fucking instructions anymore? it's for NON STRUCTURAL REPAIRS
so would I use it in this application? fuck no
this stuff is for gluing SKINS on, not structural parts.
yea, but...but..but...
you asked. I wouldn't have used it _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Feb 01, 2023 6:48 am Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
skills@eurocarsplus wrote: |
Especially Skillz
you asked. I wouldn't have used it |
The man has spoken! _________________ 73 tintop to poptop westfalia (Frankenbus) |
Posted: Wed Feb 01, 2023 6:50 am Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
I don't see volkswagen there Looks like my bus is going to explode _________________ 73 tintop to poptop westfalia (Frankenbus) |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Wed Feb 01, 2023 10:11 am Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
My battery tray was through in the center, but still had enough of a lip on that I was able to remove the center, leave 1/2" of the spot-welded edge, and trim up my replacement to sit on top of the original spot-welded lip, and was adhered in place by 3M adhesive. Since it had a fat Group 48 battery sitting on top of it, I didn't even bother doing a mechanical connection between the lip and the repair patch. The battery is bolted down, and unless you looked carefully, you wouldn't find evidence that this wasn't stock.
I appreciate the idea of the new style adhesives, but Skillz is right about using the right tool for the job.
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Bonesberg55 Samba Member
Posted: Wed Feb 01, 2023 1:07 pm Post subject: Re: Using panel bonding adhesive for inner nose valence repair |
I used that panel adhesive without the gun. I put sockets in the back end that were equal in height & then just pushed on the sockets at the same time. No problem. Unless you use that adhesive often, there is no reason for the gun. |
