malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Sun Jan 29, 2023 8:11 pm Post subject: wire connections to the starter |
Been looking at pix today to verify my connections. Bus has been under construction for 5 years now.... Getting close.
I am curious. The starter has the POST for #30 connections. and the wires have the loop connector. Plus 2 wires have female connections for what I assume are for the #50.
Question here is my starter has 2 spades, one on each side. Are they both #50?
This picture (not mine) has 2 wires but both are on one side. Does it matter?
_________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Jan 29, 2023 8:17 pm Post subject: Re: wire connections to the starter |
Campers seem to have several large ring connectors plus two 1/4 spades. I believe that it’s several wires connected to two places _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
germansupplyscott Samba Member
Posted: Sun Jan 29, 2023 9:09 pm Post subject: Re: wire connections to the starter |
malcolm2 wrote: |
If your starter has 2x 1/4" male spades on the solenoid (like in the photo) it doesn't matter where the female spades connect. Both are #50. I always but the heavy wire on the top one but I don't think it matters. _________________ SL |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jan 29, 2023 9:56 pm Post subject: Re: wire connections to the starter |
Not all solenoids are the same internally, some use that second terminal as an isolated power source for various things that need power only when cranking, like a ballast resistor bypass on cars that use that type of ignition.
On VW's they used to be all terminals activate the starter, but it's possible a replacement starter might have one that doesn't, you have a 50/50 chance, if it doesn't work try the other terminal. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3580 Location: viroqua wi.
Posted: Sun Jan 29, 2023 10:09 pm Post subject: Re: wire connections to the starter |
Ohm them out. |
Posted: Mon Jan 30, 2023 2:44 am Post subject: Re: wire connections to the starter |
Typically one is #50 and the other is unnamed. Put the big Red/Blk wire on whichever one makes the starter work and the smaller Red/Wht wire on the other. |
dodger tom Samba Member
Joined: March 25, 2013 Posts: 1272 Location: Central Coast, CA, but we're all still Ukrainian
Posted: Mon Jan 30, 2023 6:46 am Post subject: Re: wire connections to the starter |
my solenoid has an extra male spade connector (bottom of photo).
never had a wire connected to it.
and, i know my connections are substandard. you try soldering while lying on your back on the driveway.
_________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
