jonat Samba Member
Joined: July 16, 2013 Posts: 74 Location: United Kingdom
Posted: Mon Jan 30, 2023 5:39 am Post subject: Distributor cap - can this be refurbished/saved? |
I have a black, Bosch, .08, distributor cap, (#1235 522 056)
It was kept after being replaced years ago.
One of the cap plug terminals has gone green. Can this be cleaned/serviced to be used again? Ther other terminals look to be in good condition.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Mon Jan 30, 2023 5:42 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
Use a wire brush to clean the corrosion. _________________ Glenn
Member #1009
#BlueSquare |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4423 Location: Stuck in Ohio
Posted: Mon Jan 30, 2023 5:57 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
In addition to the mechanical methods of wire brush, Emery cloth, scotch brite pad, etc., there are chemical methods. I like a phosphoric acid solution, like can be found in some metal prep products. I have noticed some electrical connection sprays dissolving corrosion. White vinegar can be used as well.
The other issue is whether orn not the contacts inside the cap are grooved or pitted from the spark jumping, as that is a wear item inside the cap. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
Glenn Mr. 010
Posted: Mon Jan 30, 2023 6:10 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
Or just buy a new one for $18. _________________ Glenn
Member #1009
#BlueSquare |
PatJr Samba Member
Posted: Mon Jan 30, 2023 7:41 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
probably just clean it up
better if you have a replacement
and , how did it get that way ? The other connections look nice and clean. _________________ #############################################
1970 Transporter a orange one
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Mon Jan 30, 2023 8:09 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
Drop a few drops of Coke into that terminal & it will clean right up…. And it’ll change your perspective on whether you drink that shit again. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Mon Jan 30, 2023 10:05 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
TDCTDI wrote: |
Drop a few drops of Coke into that terminal & it will clean right up…. And it’ll change your perspective on whether you drink that shit again. |
True dat! |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Mon Jan 30, 2023 10:15 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
White vinegar will do wonders too. _________________ Come on, It's not rocket science. KISS |
KTPhil Samba Member
Posted: Mon Jan 30, 2023 10:40 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
PatJr wrote: |
and , how did it get that way ? The other connections look nice and clean. |
Probably a loose fit of the boot on the wire. A light smear of silicone sealer between the two should prevent it from happening again. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6622 Location: Houston, Texas
Posted: Mon Jan 30, 2023 4:04 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
You can clean the terminals up and make way for the electric current. Those studs are a jumping off point for the electricity from the rotor.
Not identical to yours but might work. What distributor is it for?
_________________ www.vwnos.com [email protected]
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Mon Jan 30, 2023 4:16 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
A little spritz of DeOxit works wonders - handy to have around for all sorts of electrical corrosion.
_________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Starbucket Samba Member
Posted: Mon Jan 30, 2023 4:32 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
If that's the same terminal that the inside contact (@ 1 o`clock) is don't use it if what looks like is a crack in the bakelite. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Mon Jan 30, 2023 6:27 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
Smush around some steel wool into the corroded terminal; vinegar soak there also works.
I'm hoping "smush" is a word.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn Mr. 010
KTPhil Samba Member
Posted: Mon Jan 30, 2023 10:41 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
Starbucket wrote: |
I'm not seeing a crack. There are casting flash lines and reflections; maybe that's what you are seeing?
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Tue Jan 31, 2023 6:53 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
I've never had to resort to acids or solvents to clean that sort of corrosion. WD40 will do just fine and leaves a preventive coating as well.
Search distributor tower brush or tube brush for more aggresive removal tactics, might have one at your FLAPS. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Rickf1985 Samba Member
Posted: Tue Jan 31, 2023 7:12 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
Center post to the bottom right terminal has a carbon track leading right to it. This will cause backfires and missing. The cap is junk. |
vamram Samba Member
Posted: Tue Jan 31, 2023 7:14 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
61SNRF wrote: |
WD-40 will remove that green copper corrosion w/out scrubbing? And do you have to wipe off the WD-40 residue before placing the cap back on the distributor? What about dialectic grease on the cap's copper contacts? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Tue Jan 31, 2023 8:29 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
vamram wrote: |
61SNRF wrote: |
WD-40 will remove that green copper corrosion w/out scrubbing? And do you have to wipe off the WD-40 residue before placing the cap back on the distributor? What about dialectic grease on the cap's copper contacts? |
I have often read on these forums that dielectric grease will cure anything and everything including (but not limited to) flat tires and halitosis. |
Glenn Mr. 010
Posted: Tue Jan 31, 2023 9:08 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
iowegian wrote: |
and halitosis. |
Do you apply with a tooth brush? _________________ Glenn
Member #1009
#BlueSquare |
