vamram Samba Member
Posted: Tue Jan 31, 2023 9:21 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
iowegian wrote: |
vamram wrote: |
61SNRF wrote: |
I've never had to resort to acids or solvents to clean that sort of corrosion. WD40 will do just fine and leaves a preventive coating as well.
WD-40 will remove that green copper corrosion w/out scrubbing? And do you have to wipe off the WD-40 residue before placing the cap back on the distributor? What about dialectic grease on the cap's copper contacts? |
I have often read on these forums that dielectric grease will cure anything and everything including (but not limited to) flat tires and halitosis. |
Hmmm...sounds like a thumbs down on WD-40. Easy enough to test w/the many old caps I've got laying around! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Fri Feb 03, 2023 7:28 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
Rickf1985 wrote: |
Center post to the bottom right terminal has a carbon track leading right to it. This will cause backfires and missing. The cap is junk. |
Why would you say the cap is junk? Carbon tracking is simply a line of carbon dust that has worn off of the center carbon terminal. All you have to do is wipe it off with a dry cloth.
vamram wrote: |
...WD-40 will remove that green copper corrosion w/out scrubbing? And do you have to wipe off the WD-40 residue before placing the cap back on the distributor? What about dialectic grease on the cap's copper contacts?
Hmmm...sounds like a thumbs down on WD-40. Easy enough to test w/the many old caps I've got laying around! |
WD40 does have some mild solvents that will desolve that oxidation to some degree but the old school mechanic's method is to physically remove with a coil tower brush. WD40, twist of the brush, then blow clean with compressed air.
WD40 also has mild dielectric capability, is less messy and most people have some on hand.
All dielectric grease does is seal out moisture (a nessasary component for oxidation to occur) and does not improve conductivity. The choice is yours. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
jonat Samba Member
Joined: July 16, 2013 Posts: 74 Location: United Kingdom
Posted: Thu Feb 23, 2023 5:45 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
PatJr wrote: |
probably just clean it up
better if you have a replacement
and , how did it get that way ? The other connections look nice and clean. |
Having looked back through the records, the beetle cut out whilst driving and would not start again. A roadside recovery person noted it as loss of spark, noting lead, condenser and distributor. Once at a garage, a new ignition coil, lead set, dizzy cap, rotor arm, ignition contact set, condenser and spark plugs were fitted. (This is when the bosch black cap was replaced)
The original '72 dated bosch short coil was replaced at the time. I kept and recently tested this and found ohms and resistence tested well. Perhaps the coil was fine and could have been left in?
I tried own brand coke/white vinegar which made a slight difference but has not given the shine yet in the terminal I may try the coil tower brush suggestion by @61SNRF or squash in the steel wool. Regarding @heimlich 's question, the current distributor is 009. (looking to replace with original restored vacuum 205AL) Responding to @Starbucket I've looked closer, and not felt or seen any cracks, so it may just be a light scratch.
bnam Samba Member
Joined: July 02, 2006 Posts: 2935 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Feb 23, 2023 7:14 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
I cut a strip of abrasive paper - say 100 grit into a roll that fits into the opening and turn it around (in the direction you rolled it). You can even wrap it around an appropriately sized bit and run it with a dremel. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Thu Feb 23, 2023 7:21 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
Sure sounds like a lot of work for a $20 part that is meant to wear and be replaced. _________________ Glenn
Member #1009
#BlueSquare |
bnam Samba Member
Posted: Thu Feb 23, 2023 9:10 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
Glenn wrote: |
Sure sounds like a lot of work for a $20 part that is meant to wear and be replaced. |
I hate fueling the disposable consumption mentality that contributes to our landfills. If I can get more life out of a part with some effort on my part (this only take 5 mins in this case), I will. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Glenn Mr. 010
Posted: Fri Feb 24, 2023 4:19 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
bnam wrote: |
Glenn wrote: |
I hate fueling the disposable consumption mentality that contributes to our landfills. If I can get more life out of a part with some effort on my part (this only take 5 mins in this case), I will. |
Get a refillable water bottle and don't buy water in stores, you'll save more from the landfill than fixing your distributor cap. _________________ Glenn
Member #1009
#BlueSquare |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Fri Feb 24, 2023 7:07 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
Glenn wrote: |
Agree.
Glenn - being smart can be a curse ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn Mr. 010
Posted: Fri Feb 24, 2023 7:21 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
Cusser wrote: |
Glenn wrote: |
Agree.
Glenn - being smart can be a curse ! |
Yes... ignorance is bliss. _________________ Glenn
Member #1009
#BlueSquare |
bnam Samba Member
Posted: Fri Feb 24, 2023 9:07 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
I enjoy being able to repair parts and reuse them - and get satisfaction out of getting extra life out of original parts. The waste and energy reduction potential is an added bonus. I do happen to use refillable bottles - a personal preference. And I don’t look down on people who choose a different path. YMMV.
Cheers! _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Rickf1985 Samba Member
Posted: Fri Feb 24, 2023 9:30 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
You can try to clean the carbon track. what you will find is that it is not just a dust trail but a burnt in etch in the bakelite cap. This is a condition that has happened to vehicles for as long as they have had distributor caps. I have NEVER seen one that was a dust trail. But if you want to spend some time on it then go for it. I know I would not depend on that cap on the road. |
Starbucket Samba Member
Posted: Fri Feb 24, 2023 1:46 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
When you clean it up and reinstall it and it runs like crap you will remember why you replaced it years ago. That carbon track will rob voltage from the other cylinders and I bet it leads to the green post. If you like repairing electrical components buy a can of "Deoxit D5" and make life easier. |
TornadoRed06 Samba Member
Joined: August 30, 2020 Posts: 198 Location: Porto - Portugal
Posted: Fri Feb 24, 2023 3:04 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
bnam wrote: |
Cheers! |
Yet, lots of people say that is ignorance/unsmartness...
Save that part, otherwise, what's the point on all this keeping & driving ''old *sugar*"? |
Glenn Mr. 010
Posted: Fri Feb 24, 2023 3:09 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
bnam wrote: |
Cheers! |
I do also, but some parts are not intended to be "rebuilt". No one relines brake shoes and recaps tires.
And some can be... over 3000 done over 22 years.
Member #1009
#BlueSquare |
Cusser Samba Member
Posted: Fri Feb 24, 2023 3:31 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
bnam wrote: |
I enjoy being able to repair parts and reuse them - and get satisfaction out of getting extra life out of original parts. The waste and energy reduction potential is an added bonus. I do happen to use refillable bottles - a personal preference. And I don’t look down on people who choose a different path. |
I also enjoy being able to repair parts and reuse them - and get satisfaction out of getting extra life out of original parts. The waste and energy reduction potential is an added bonus. I do happen to use refillable bottles - a personal preference. But I do look down on people who choose a different path. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Fri Feb 24, 2023 6:30 pm Post subject: Re: Distributor cap - can this be refurbished/saved? |
When I was 18 years old and working in a general repair garage/gas station it was standard practice, when doing a tune-up, to wash the inside of a distributor cap with soap and water-----and of course drying with compressed air.
But that was 60 years ago and a lot of folks were poor. |
Posted: Sat Feb 25, 2023 10:30 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
And I do reline brake shoes but do you know that in that process you l also need to reshape the backing so that it fits the contour of the drum? Just riveting a new lining on the old backer is easy, doing it correctly is a bit harder. To refurbish a distributor cap you would need some way to push out the old terminals and replace them with new terminals to maintain the proper air gap between terminal and rotor. That cap with the carbon track already has worn terminals. And do you know what causes carbon tracking? It is not dust from the carbon, it is a bad plug wire or a plug wire that has been left off and the voltage has found a new path. |
jonat Samba Member
Posted: Fri Mar 03, 2023 4:30 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
Rickf1985 wrote: |
When the bug cut out whilst out driving, with 'loss of spark' noting lead, condenser and distributor to be looked at by the roadside recovery, Would you say it was necessary to have had the the ignition coil replaced at the garage? |
Posted: Fri Mar 03, 2023 10:01 am Post subject: Re: Distributor cap - can this be refurbished/saved? |
No, I would have done further diagnosis at the garage and would have found the bad cap and replaced it without having to replace any other parts, besides the rotor, thereby saving the customer money and sending him on his way. I owned a shop for many years and most of my customers were word of mouth customers. I did very little advertising and what I did was in the way of sponsoring ball games and such. I had a very full clientele. |
