69bluebugboi Samba Member
Joined: August 23, 2022 Posts: 10 Location: Orange county
Posted: Mon Jan 30, 2023 11:10 am Post subject: Possibly purchased wrong electronic ignition |
I purchased a Pertronix electronic ignition however, I noticed that it would not fully seat at the bottom due to the black tab that's in the image below.
I ended up looking up a different style of Pertronix electric ignition and came across one that has a moon shape to it. Would this be the correct one for my distributor? I'm almost certain I've purchased the wrong one but would like to make sure first.
Moon-shaped Pertronix electronic ignition: https://www.jbugs.com/product/1847V.html
Zundfolge1432 Samba Member
Posted: Mon Jan 30, 2023 11:37 am Post subject: Re: Possibly purchased wrong electronic ignition |
Wow I could buy a lifetime supply of points for 115.00 dollars. 😀 |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Mon Jan 30, 2023 2:47 pm Post subject: Re: Possibly purchased wrong electronic ignition |
Yes you want the moon shaped one.
$115.00 may seem like a lot. I paid $79.00 for mine but that was in 1991.
Still works great. Make sure it’s a Pertronix I. Those work with a stock coil and plug wires. The II and III require a different coil and plug wires. _________________ Volkswagen!
(Compression 8.7:1) |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Mon Jan 30, 2023 4:59 pm Post subject: Re: Possibly purchased wrong electronic ignition |
You bought one for a mechanical only distributor.... yours has mechanical and vacuum advance.
It's the wrong part. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jan 30, 2023 5:25 pm Post subject: Re: Possibly purchased wrong electronic ignition |
jeffrey8164 wrote: |
Still works great. Make sure it’s a Pertronix I. Those work with a stock coil and plug wires. The II and III require a different coil and plug wires. |
Yes I’m still using points made in the 60s |
Posted: Mon Jan 30, 2023 6:18 pm Post subject: Re: Possibly purchased wrong electronic ignition |
Zundfolge1432 wrote: |
Glenn Mr. 010
Posted: Mon Jan 30, 2023 6:23 pm Post subject: Re: Possibly purchased wrong electronic ignition |
A lot of people use points.
Member #1009
#BlueSquare |
irvanm Samba Member
Joined: January 09, 2008 Posts: 609 Location: Lawrence, Kansas
Posted: Mon Jan 30, 2023 7:30 pm Post subject: Re: Possibly purchased wrong electronic ignition |
Glenn for the win. |
Glenn Mr. 010
Posted: Mon Jan 30, 2023 7:31 pm Post subject: Re: Possibly purchased wrong electronic ignition |
irvanm wrote: |
The box is 8" deep _________________ Glenn
Member #1009
#BlueSquare |
doug bugg Samba Member
Joined: March 08, 2003 Posts: 349 Location: Minneapolis
Posted: Tue Jan 31, 2023 8:30 am Post subject: Re: Possibly purchased wrong electronic ignition |
Yes! I inherited a bug with a BRAND NEW Pertronix and it was junk. Go back to points! _________________ "Knowledge is Good" - Faber College |
Posted: Tue Jan 31, 2023 9:39 am Post subject: Re: Possibly purchased wrong electronic ignition |
Thankfully we have choices so whichever you choose that is right for you. It may sound as though I’ve disparaged pertronix, I’m sorry. |
BenJAMin Samba Member
Joined: February 01, 2004 Posts: 461 Location: Michigan
Posted: Tue Jan 31, 2023 12:41 pm Post subject: Re: Possibly purchased wrong electronic ignition |
For what it's worth my Pertronix is 21 years old. Never had a problem with it. I also have hydraulic lifters. Makes owning one of these cars much more pleasant along with the 4 wheel discs. |
Glenn Mr. 010
