Joined: January 30, 2023 Posts: 1 Location: Tucson, AZ
Posted: Mon Jan 30, 2023 7:21 pm Post subject: Trans rebuild kits |
Last night I was cut off, and missed my shift and blew out second gear, I’ve been searching all day for a rebuild kit to no avail. Does anyone have any ideas as to where I can get one? I have a 1969 westfalia with the original trans, probably has well over 300,000 miles on it, so a rebuild would be a good idea anyway. I’ve never built a trans before, so after 30+ years of building engines and all other VW issues I’ve battled, I want to give it a shot. Any help would be much appreciated!
Thank you,
Bjorn. |
Xevin Samba Member
Posted: Mon Jan 30, 2023 7:26 pm Post subject: Re: Trans rebuild kits |
Welcome.
Have a look here. You might consider having this moved to the performance/engines/transmission forum
https://www.thesamba.com/vw/forum/viewtopic.php?t=770207&highlight=trevor _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Mon Jan 30, 2023 7:29 pm Post subject: Re: Trans rebuild kits |
Agreed... moved. _________________ Glenn
Member #1009
#BlueSquare |
SGKent Samba Member
Posted: Mon Jan 30, 2023 9:35 pm Post subject: Re: Trans rebuild kits |
rebuilding transmissions is not as easy as it seems for the skilled mechanic. That said, the investment in tools is more than the cost of a rebuilt transmission. Weddle transmission sells the parts. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
SGKent Samba Member
Posted: Mon Jan 30, 2023 9:36 pm Post subject: Re: Trans rebuild kits |
The best transmission builder if you are in Tucson is Eric at Transworks in El Cajon, San Diego CO CA. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
texastomeh Samba Member
Joined: November 20, 2018 Posts: 291 Location: Dallas, TX
Posted: Tue Jan 31, 2023 6:10 pm Post subject: Re: Trans rebuild kits |
Not to sidetrack the thread, but what if you just want to "freshen-up" tranny with new external gaskets, seals, and bushings while you have the engine out?
I don't want to tear into the tranny since it was performing satisfactorily when I pulled the engine, but I have no idea how old the gaskets and etc. are.
I already plan to install new mounts, so will essentially (if not totally) be removing the tranny prior to engine installation. Also plan to install a new TO bearing.
I appreciate any suggestions on things to do "while I am in there anyway".
Tom _________________ A new engine build won't solve ALL of life's problems - only those THAT REALLY MATTER!!!
GETTING old was GREAT - BEING old SUCKS!!
Too bad that the guys that know how to solve all of the WORLD's problems are too busy working on old Volkswagens!! |
allamaabroad Samba Member
Joined: September 22, 2016 Posts: 560 Location: South Jordan, Utah
Posted: Tue Jan 31, 2023 11:49 pm Post subject: Re: Trans rebuild kits |
texastomeh wrote: |
Tom |
I did this when I bought my Bay Window, in hopes of prolonging the life of the transmission. Weddle had all the gaskets I needed in a kit for the 002 transmission, then I bought input and output seals, nose cone bushings and seal, upgraded hockey stick and steel shift ball, and a mainshaft bearing plate all from Weddle as well. I think it cost me about $100 to do all that, fixing any potential leaks and all common failure points on the 002 transmission.
A similar thing could be done on any VW transmission, although keep in mind there's only so much you can do without investing in tools and jigs.
-Check nose cone/hockey stick bushings and seal; When worn these cause sloppy shifting.
- Replace input and final drive shaft seals
- Replace side cover O-ring/Gaskets
- Replace nose cone gasket
- Flush and refill fluid
Just be careful to not go too deep. If you go much farther than that, you can easily screw up adjustments within the transmission, leaving you in a worse position than before. _________________ Dennis - 1973 Super Beetle ('16-'21)
Debbie- 1970 Baywindow Bus ('21 - Present)
Tin top camper/adventure bus
2180 TW: CNC Panchitos, Beehives Done Right, Web 163, Ultralight Lifters, 1.3 Rockers, CSP Python, Custom Speeduino EFI Conversion with 40mm Throttle Bodies
Distributors are lame
I have a really hard time leaving things alone...
Innovative and affordable engine management systems and EFI conversions for your Vintage VW
Visit https://debbiesaircooled.com/ |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Feb 01, 2023 5:37 am Post subject: Re: Trans rebuild kits |
If you're resourceful and able to make/ improvise tools, you can probably get through it. You'll need a dead trans case to cut up for a shift fork jig, and a special socket for the pinion nut (not sure what that bus trans uses), and the full range of micrometers, calipers, dial indicators.
You'll probably need some new/ used parts, and that's where things get tricky, because some things are a direct substitution, and some require other changes to make everything work. If this makes you uneasy send it out, but if you feel confident I say go for it. I've done 6 basically stock rebuilds, with zero factory tools, and none have spit parts back yet. _________________ modok wrote:
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
CrazyTestPilot Samba Member
Joined: May 05, 2022 Posts: 208 Location: Seattle, WA.
Posted: Wed Feb 01, 2023 10:16 am Post subject: Re: Trans rebuild kits |
these guys have it almost for sure... https://www.transtar1.com/ |
