Sonny29 Samba Member
Joined: November 12, 2018 Posts: 44 Location: Valdosta,Georgia
Posted: Tue Jan 31, 2023 3:07 pm Post subject: ? Size socket back axle 76 Baywindow |
Was told a size 45mm socket is what I needed. It’s to small. Also a 1 3/4 “ is to small. Help please! _________________ Ain’t nothing to it but to do it! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Tue Jan 31, 2023 3:11 pm Post subject: Re: ? Size socket back axle 76 Baywindow |
46mm _________________ Glenn
Member #1009
#BlueSquare |
wrxnofx Samba Member
Joined: July 06, 2022 Posts: 224 Location: Richfield, MN
Posted: Tue Jan 31, 2023 4:29 pm Post subject: Re: ? Size socket back axle 76 Baywindow |
Just went through this. As Glenn stated, it's a 46mm, which no one local to me carried so had to order.
Alternatively, a 1 13/16" socket is the same size, and you'll most likely be able to find one of those at a Menards/Home Depot in 3/4" drive. 'Murcah is annoyingly easy to find, whereas metric is not. _________________ 1977 VW Type 2 Bay Window Westy FI |
timvw7476 Samba Member
Posted: Tue Jan 31, 2023 4:44 pm Post subject: Re: ? Size socket back axle 76 Baywindow |
the EMPI brand axle nut whacker is really nice.
Just a crude hoop with a 46mm six-sided hole in it, provision for a 1/2" breaker or massive ratchet, + surface for adding hammer/maul power so nothing stands in your way. Confidence inspiring. |
Abscate Samba Member
Posted: Tue Jan 31, 2023 6:16 pm Post subject: Re: ? Size socket back axle 76 Baywindow |
Heat a stuck one nice and hot, use thermo, not Mongo. _________________ .ssS! |
Posted: Tue Jan 31, 2023 6:36 pm Post subject: Re: ? Size socket back axle 76 Baywindow |
Thanks friends for your help! _________________ Ain’t nothing to it but to do it! |
Posted: Tue Jan 31, 2023 7:52 pm Post subject: Re: ? Size socket back axle 76 Baywindow |
Buy a set of Vanagon axle nuts and then you Vanagon tightening specs. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3580 Location: viroqua wi.
Posted: Tue Jan 31, 2023 8:23 pm Post subject: Re: ? Size socket back axle 76 Baywindow |
Wildthings wrote: |
360 foot lbs? |
Posted: Tue Jan 31, 2023 10:08 pm Post subject: Re: ? Size socket back axle 76 Baywindow |
bsairhead wrote: |
Wildthings wrote: |
360 foot lbs? |
Yes a minimum of 360 ft*lbs while the maximum potential torque will not increase as the Vanagon nut has more castellations in it. |
Posted: Tue Jan 31, 2023 10:13 pm Post subject: Re: ? Size socket back axle 76 Baywindow |
Wildthings wrote: |
bsairhead wrote: |
Wildthings wrote: |
360 foot lbs? |
More Castellantions means more slots? |
Posted: Wed Feb 01, 2023 12:40 am Post subject: Re: ? Size socket back axle 76 Baywindow |
bsairhead wrote: |
Wildthings wrote: |
bsairhead wrote: |
Wildthings wrote: |
360 foot lbs? |
Yes |
