fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Tue Jan 31, 2023 3:40 pm Post subject: Porsche 356 and 912 90mm 12v Gen-which backing plate |
I'm converting my '59 36hp engine from 6 to 12 volts, and have a 38 amp 90mm 12 volt 356/912 generator lined up. I just have to source a backing plate and fan. Which fan and backing plate should I use - the matching 356/912 one or will a vw 36hp backing plate and fan work?
Thank you
Ted |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Tue Jan 31, 2023 3:48 pm Post subject: Re: Porsche 356 and 912 90mm 12v Gen-which backing plate |
I used 36hp parts and the 90mm generator was a direct bolt in. _________________ modok wrote:
Posted: Tue Jan 31, 2023 4:00 pm Post subject: Re: Porsche 356 and 912 90mm 12v Gen-which backing plate |
Awesome thank you esde. This should save me from buying the wrong parts.
Ted |
wdfifteen Samba Member
Posted: Wed Feb 01, 2023 10:18 am Post subject: Re: Porsche 356 and 912 90mm 12v Gen-which backing plate |
Are the 36 hp and 356 different? |
Posted: Wed Feb 01, 2023 11:32 am Post subject: Re: Porsche 356 and 912 90mm 12v Gen-which backing plate |
That is what I was wondering. I wanted to play it safe and ask which one fits for sure. From what esde said it does. If a 356/912 backing plate is the same, then I can buy either.
Ted |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Wed Feb 01, 2023 1:08 pm Post subject: Re: Porsche 356 and 912 90mm 12v Gen-which backing plate |
I run the stock 36hp pulley. The later pulley is larger and would require a longer belt. Your fan would be spinning slightly slower. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
Posted: Wed Feb 01, 2023 1:29 pm Post subject: Re: Porsche 356 and 912 90mm 12v Gen-which backing plate |
Thanks petrol, this is what I will also do - run the 36hp pulley which I already have.
Ted |
