ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4188 Location: Pasadena CA/DTLA soon China
Posted: Tue Jan 31, 2023 8:51 pm Post subject: Fender Beading question |
Other than the obvious, later years offered different colors. Is there any difference in early vs late type 3 fender beading. I can tell the difference between notch vs square and fastback. I am talking length. Please advise.
Martin
allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
mdege Samba Member
Joined: January 16, 2018 Posts: 939 Location: Niederkruechten, Germany
Posted: Wed Feb 01, 2023 8:00 am Post subject: Re: Fender Beading question |
Thank You Sir for the info. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3686 Location: San Jose, CA
Posted: Wed Feb 01, 2023 10:42 am Post subject: Re: Fender Beading question |
I believe the upper front fender/cowel portion is shorter on later models. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Sat Feb 11, 2023 8:44 pm Post subject: Re: Fender Beading question |
So, to answer my own question, I found out that late front type 3 beading is 2" shorter on the front cowl
and 3" longer on the apron section.
What this may help many type 3 owners is that if you can find useable late front fender beading, you will have enough of the ELUSIVE T profile beading for the rear apron on Squarebacks and Fastbacks.
Square and Fasty rear aprons need only about 10" of T profile beading, and Late type 3 front beading has an excess of 19"
Hope this helps many of you who are looking for those ALMOST IMPOSSIBLE to find rear apron fender beadings for your project.
I have several pieces in white if any one is interested.
Martin
notchboy Samba Member
Joined: April 27, 2002 Posts: 22457 Location: Escondido CA
Posted: Sun Feb 12, 2023 10:52 am Post subject: Re: Fender Beading question |
I think the short spot at the top may be shrinkage. When I restored the 62 Anthracite notch it was short and I had Anthracite early beading. And I do also remember it being long at the bottom. I heated it and pulled it to fit. Maybe the changes in the profile from T to O make it do this shrinking weird over time? No se?
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sun Feb 12, 2023 12:59 pm Post subject: Re: Fender Beading question |
notchboy wrote: |
I agree with you Mr Notchboy, shrinkage does occur, I recall selling a diamond blue front hood handle seal and getting negative feedback for not fitting. Though I just learned late beading us shorter on the front cowl section and longer on the Front apron by a few inches. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Posted: Sun Feb 12, 2023 5:17 pm Post subject: Re: Fender Beading question |
Why would it be shorter up by the front cowl? That section is the same on all Type 3s, no? Or are you going by your side by side comparison - which is why I said shrinkage. _________________
t3kg wrote: |
1964 1500 S
