Could this trans be a Berg 5 speed?
veedweeb
veedweeb is offline
PostPosted: Thu Feb 02, 2023 9:53 am    Post subject: Could this trans be a Berg 5 speed? Reply with quote
Just looking at the intermediate section of the casing and it looks different to a stock one to me.
Plus the car has a Berg 5 shift lever. Is it possible to tell whether or not the trans is a 5 speed?
1963 Turbo WBX Bug
2000 Sedan Clasico Mexican Bug
1972 Type 3 Squareback
mcmscott
mcmscott is offline
PostPosted: Thu Feb 02, 2023 10:04 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
Looks to be an early one
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
veedweeb
veedweeb is offline
PostPosted: Thu Feb 02, 2023 10:07 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
An early Berg or just an early stock one?
1963 Turbo WBX Bug
DerrickfromNC1
DerrickfromNC1 is offline
PostPosted: Thu Feb 02, 2023 11:13 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
Can you get in and go thru the shift pattern? My tranny is a 5 speed Transform which I understand was based off the earlier Berg 5speed. My 5th is to the right of 3rd gear. My shifter is a Hurst that I clearances the base plate in order to be able to reach reverse and allow enough movement to engage the 5th gear.
mcmscott
mcmscott is offline
PostPosted: Thu Feb 02, 2023 11:42 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
Berg
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
veedweeb
veedweeb is offline
PostPosted: Thu Feb 02, 2023 12:42 pm    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
That's not really an option, unfortunately. The car it's in is for sale at the other end of the country and if I start asking the seller questions, it'll double the price!!
1963 Turbo WBX Bug
veedweeb
veedweeb is offline
PostPosted: Thu Feb 02, 2023 12:43 pm    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
mcmscott wrote:
Berg
Cool, thank you 👍
1963 Turbo WBX Bug
Dan Ruddock
Dan Ruddock is offline
PostPosted: Thu Feb 02, 2023 1:55 pm    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
Looks like kit car. What is it?
veedweeb
veedweeb is offline
PostPosted: Fri Feb 03, 2023 12:23 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
It's a quite nice looking and actually fairly rare kit car, which is probably worth the asking price, but I spotted the shifter and non-stock looking trans so I thought I'd do a bit more research before buying it.
If I end up buying it, I'll post more pics.
1963 Turbo WBX Bug
veedweeb
veedweeb is offline
PostPosted: Fri Feb 03, 2023 2:58 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
This is all academic now because the car has sold before I could get it!
Thanks for the replies everyone.
1963 Turbo WBX Bug
madmike
madmike is offline
PostPosted: Fri Feb 03, 2023 5:35 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
So WTF was it ? Kelmark, GT 40 of sme sort? Laughing
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
veedweeb
veedweeb is offline
PostPosted: Fri Feb 03, 2023 5:42 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
It's a Fiberfab Jamaican 2
Specifically, this one is quite well known apparently.
It was converted into a steam powered vehicle by someone called Peter Barrett and then was imported to the UK in about 2009 by Greg Walker.
Sad to see it in the state it's in now, but if you Google Barrett Steam car you'll find info about it.
1963 Turbo WBX Bug
DerrickfromNC1
PostPosted: Fri Feb 03, 2023 8:26 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
Wouldn’t be surprised if someone following this thread brought it out from under you! Happened to me once….ran my mouth on samba regarding a Bosch 010 & a Mallory dual point I discovered at an old VW repair shop off the beaten path that had long since transitioned from aircooled VW to Imports in general. Went back the next morning with my $75 and both were gone. Owner said someone came by later that afternoon(shortly after I reported my good fortune on samba) paid the $75 supposedly on my behalf for the distributors.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Feb 03, 2023 9:22 am    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
Wasn't me.
Glenn
Member #1009
#BlueSquare
b-man
b-man is offline
PostPosted: Fri Feb 03, 2023 5:25 pm    Post subject: Re: Could this trans be a Berg 5 speed? Reply with quote
Pro tip:
Now that you’ve been on the Samba for several years you probably know who the transaxle builders are who post here.
Send one of them a message and ask privately instead next time, it’s usually pretty easy for internet deal hunters to identify the car you were looking at and get sniped.
1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
