cosmadonic Samba Member
Posted: Thu Feb 02, 2023 2:48 pm Post subject: Leveling front end |
Hi folks- would appreciate a few thoughts on a 1957 VW bug front end. It was in a dune buggy that I have restored, when sitting on a level surface the driver side front end beam side sits 2 inchs lower to the ground then the passenger side. ( front end is about 200lbs maybe less) I've though maybe coil over shocks would be able to change the height, but from reading most say it will just change stiffness of ride. So is the installation a new set of torsion leaf springs the answer, just wanting to make sure I'm not missing something else. Thank You
Thank You for the reply's and suggestions. Turns out to be it was a new shock absorber that was frozen and once compressed would not pull back out.
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34018 Location: Conejo Valley, CA
Posted: Thu Feb 02, 2023 4:07 pm Post subject: Re: Leveling front end |
Something may be bent. Check that first, side to side, or to another car. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Thu Feb 02, 2023 4:15 pm Post subject: Re: Leveling front end |
Might be bent. I would check the spring pack to make sure they are all there and in line with the grub screws properly seated.
I can’t remember off hand if you can simply turn them end for end. I think the grub screw dimple is different side to side.
How’s the rear? _________________ Volkswagen!
(Compression 8.7:1) |
AlainTodd Samba Member
Joined: February 03, 2023 Posts: 1 Location: Huntington Beach
Posted: Fri Feb 03, 2023 12:52 pm Post subject: Re: Leveling front end |
If everything checks out ok, you might double-check the rear heights -- I believe that if the rear has been lifted/lowered by adjusting the torsion spring/plate, and whoever did it didn't get the adjustment exactly equal on both sides, so that the passenger side is high (as compared to the driver side), I've been told that it can push the driver side front end low. |
