DC stance
Glsb
Glsb is offline
PostPosted: Fri Feb 03, 2023 6:21 am    Post subject: DC stance Reply with quote
C
onsidering this purchase of a split but am not a fan in how it sits or the wheels tucked under. Since it's a straight axle would it be worth it to extend the axle and change the spindles back to stock? Shocks would also need to changed? Seems like a nice meaty front end. Plan would be to install disc up front if that matters
Is the rear a stock axle?
Thanks for any help
Braukuche
Braukuche is offline
PostPosted: Fri Feb 03, 2023 8:25 am    Post subject: Re: DC stance Reply with quote
Narrowed beam. Not original.
If you buy it you could probably easily sell that one and buy a good used original beam if your plan is to being it up to stock height. There are plenty of disc kits for original beam/spindle set ups available.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
Clara Premium Member
Clara is offline
PostPosted: Fri Feb 03, 2023 12:19 pm    Post subject: Re: DC stance Reply with quote
X2 on custom beam. Not impressed with masking job on those spindles.
If you don’t like the stance, factor in buying a transaxle and a beam and installation..
And tires too, and possibly wheels
Is that tire low?
don.ville Premium Member
Samba YardMan
don.ville is offline
PostPosted: Sun Feb 05, 2023 6:58 pm    Post subject: Re: DC stance Reply with quote
That is an expensive fully built beam.
Someone on the 'net will be looking to lower their bus and would love to trade with you
Find someone near you that will swap their front beam with you: facebook, instagram, thesamba
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
