Jim Grease Samba Member
Posted: Fri Feb 03, 2023 6:31 am Post subject: My 71 has a retrofitted oil filter... |
It's pretty new to me, and so is the vintage VW world. My question: Since it has a retrofitted place for an oil filter, the kind you'd see on a modern car, do I need to disassemble the sump when I change the oil? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Fri Feb 03, 2023 6:39 am Post subject: Re: My 71 has a retrofitted oil filter... |
Pictures?
Is it a spin on or a cartridge in the sump? _________________ Glenn
Member #1009
#BlueSquare |
richparker Samba Member
Joined: November 24, 2011 Posts: 6980 Location: Durango, CO
Posted: Fri Feb 03, 2023 6:51 am Post subject: Re: My 71 has a retrofitted oil filter... |
Many of us have aftermarket spin on oil filters. Some are mounted separate from the engine and have have hoses (oil lines) running to them and some mount directly to the oil pump.
There’s most likely no need to disassemble anything, just drain the oil and change the filter.
What type of oil to use is a like opening a can of worms. As far as filters, you can’t go wrong with a Wix or a Napa Gold. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Fri Feb 03, 2023 7:13 am Post subject: Re: My 71 has a retrofitted oil filter... |
Thanks, fellas. It's a spin-on oil filter, just like you'd find in any modern car, and it's not near the sump itself. I got the oil recs from the dudes in the desert who did some transmission work after I acquired the bus, and I've changed the oil myself once, but I was just wondering how necessary sump disassembly is since it's got the updated filter. |
Glenn Mr. 010
Posted: Fri Feb 03, 2023 7:33 am Post subject: Re: My 71 has a retrofitted oil filter... |
Not sure why you think anything needs to be done to the sump. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Feb 03, 2023 7:47 am Post subject: Re: My 71 has a retrofitted oil filter... |
My bad, y'all - I'm talking about the assembly where the oil plug is, with the cardboard gasket, screen, etc. My apologies for the f'd terminology. |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1084 Location: wherever my baywindow takes me.
Posted: Fri Feb 03, 2023 8:11 am Post subject: Re: My 71 has a retrofitted oil filter... |
If the bus is "new to you" I would drop the strainer plate inspect the strainer and the inside of the plate for signs of trouble. Clean it up real good and install it back.
This is something I would think you would want to know initially with your first oil change. Then you can choose to ignore it after that if you like. I say this because my take on that sump strainer is that it keeps any large chunks of matter that get dislodged in the crankcase and will never see the exteral filter, from getting sucked into the pick up for the oil pump.
Mi dos centavos. |
PatJr Samba Member
Posted: Fri Feb 03, 2023 8:30 am Post subject: Re: My 71 has a retrofitted oil filter... |
flame suit on
I would take the sump plate (?) off and clean or replace the screen at least once and/or every 3 or 4 oil changes. The spin on filter, get the cheaper ones and replace them every time the oil is changed or sooner. Check out Ford Boss Me on youtube or similar channels, there are a lot of videos where they cut those filters open and do some rough testing. Interesting stuff. _________________ #############################################
1970 Transporter a orange one
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Fri Feb 03, 2023 8:55 am Post subject: Re: My 71 has a retrofitted oil filter... |
on a type 1 engine you can leave the sump plate on, and just pull the plug. check it every 2nd or 3rd oil change, it's only going to stop big particles with the mesh screen anyways, the remote oil filter will catch most everything else.
I use the short filters on mine: K&N 2004, Mobile M1-204, Wix 51068 _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Fri Feb 03, 2023 10:11 am Post subject: Re: My 71 has a retrofitted oil filter... |
Avoid running SAE SF and earlier oils, particularly multigrades (none of which are readily available any more) and check and clean the oil pickup screen the first time you do an oil change. Afterward run something between a 5w30 and 15w40 synthetic and check the screen every 50-100K miles. Assuming your engine wasn't built with extremely loose tolerances, save the 20w50 for when its 115°F+ out.
Pictures of you oil filter setup and any added oil cooler would be nice. |
germansupplyscott Samba Member
Posted: Fri Feb 03, 2023 11:29 am Post subject: Re: My 71 has a retrofitted oil filter... |
On a new-to-me engine I would absolutely remove the sump plate and screen, clean, replace. You'll learn a bit about the condition of the engine and how it's been maintained. _________________ SL |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3561 Location: viroqua wi.
Posted: Fri Feb 03, 2023 12:10 pm Post subject: Re: My 71 has a retrofitted oil filter... |
Yes do a screen pull and clean. You might find chunks of plastic valve guide seals. Don't freak out if you do. If you find metal than you can freak. |
Glenn Mr. 010
Posted: Fri Feb 03, 2023 12:32 pm Post subject: Re: My 71 has a retrofitted oil filter... |
You never know what you'll find.
Member #1009
#BlueSquare |
Posted: Fri Feb 03, 2023 12:47 pm Post subject: Re: My 71 has a retrofitted oil filter... |
Glenn wrote: |
Beautiful lead sludge, don't see much of that anymore, with lead being passe for 40ish years now. |
Glenn Mr. 010
Posted: Fri Feb 03, 2023 12:53 pm Post subject: Re: My 71 has a retrofitted oil filter... |
Wildthings wrote: |
Glenn wrote: |
That's the cam lobes from #1 and #3. _________________ Glenn
Member #1009
#BlueSquare |
SGKent Samba Member
Posted: Fri Feb 03, 2023 3:55 pm Post subject: Re: My 71 has a retrofitted oil filter... |
what year bus is this sump plate on? On a 1972-1979 DO NOT tighten the acorn nut to more than 9 ft lbs or it will destroy the engine. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Fri Feb 03, 2023 6:33 pm Post subject: Re: My 71 has a retrofitted oil filter... |
I think you’ve got your answer _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sat Feb 04, 2023 11:11 am Post subject: Re: My 71 has a retrofitted oil filter... |
Thanks very much for the info, everybody. Greatly appreciated.
Gonna embark on the oil change tomorrow a.m. Deséame suerte por favor. |
