rustybug1990 Samba Member
Posted: Fri Feb 03, 2023 12:06 pm Post subject: Which carb for turbo build? IDF or IDA |
I am about to embark on an engine building journey and I am trying to figure some things out. I know I want to run a blow through turbo with dual carbs, the rest is up in the air right now. This will be a weekend warrior kind of car build, nothing too pretty just fast and fun, maybe even take it to the drag strip occasionally. So starting off, should I go IDF or IDA carbs? I don't know nearly enough about them to know which way to go. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2219 Location: HdG, MD & NJ
Posted: Fri Feb 03, 2023 12:51 pm Post subject: Re: Which carb for turbo build? IDF or IDA |
Blow through IDF’s are a common thing. Blow through IDA’s are not. So, there’s more info out there for the IDF’s. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Feb 03, 2023 4:10 pm Post subject: Re: Which carb for turbo build? IDF or IDA |
Dells is the Carbs ya need , they have throttle shaft seals from the factory
IDFs work for low boost or the carbs leakish _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Dauz Samba Member
Posted: Fri Feb 03, 2023 4:22 pm Post subject: Re: Which carb for turbo build? IDF or IDA |
You will have to have the shafts sealed up for anything over 7 lbs. in my experience.
I have seen most machine the body for seals and some machine the shaft for O-rings…personally I have never done it. |
