shawnyb35 Samba Member
Joined: February 03, 2023 Posts: 4 Location: Knoxville
Posted: Fri Feb 03, 2023 1:42 pm Post subject: Front driver side signal |
Stuck and can’t figure out what’s going on. Front driver side signal will not flash when I have my headlights on. Works perfectly fine when the lights are off. Cleaned the ground wire in front of the gas tank hoping that might help but had no change. Appreciate any suggestions. Thanks |
Joined: August 31, 2013 Posts: 12854 Location: North Carolina
Posted: Fri Feb 03, 2023 1:49 pm Post subject: Re: Front driver side signal |
Check for wrong bulb, or bulb that is incorrectly installed. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Feb 03, 2023 2:38 pm Post subject: Re: Front driver side signal |
Thanks for the advice. I swapped the working bulb from the other side and it still did not flash. |
Starbucket Samba Member
Posted: Fri Feb 03, 2023 3:54 pm Post subject: Re: Front driver side signal |
What did you do before this started happening? All the turn signial bulbs need to be the same wattage (it say's on your relay what that is I think 23w). |
Posted: Sat Feb 04, 2023 7:46 pm Post subject: Re: Front driver side signal |
The signals have been like this since I purchased the car. |
Posted: Sat Feb 04, 2023 8:18 pm Post subject: Re: Front driver side signal |
Compare the wiring of the wirking side to the non working side (if the parking light and turn signal wires are switched the watts will be wrong). Wiring diagrams are at top of page under Technical/type1/wiring diagrams/your year.
Make sure the contacts and side ground in the socker are clean and shiny. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6609 Location: Houston, Texas
Posted: Sat Feb 04, 2023 8:34 pm Post subject: Re: Front driver side signal |
Get your multimeter out. Start at the light and trace it back to the relay, switch, and fuse box. _________________ www.vwnos.com [email protected]
Posted: Sat Feb 04, 2023 10:06 pm Post subject: Re: Front driver side signal |
Thanks all going to get on this in the morning. Will report back with results. Thanks again! |
