Zundfolge1432 Samba Member
Posted: Sat Feb 04, 2023 6:05 pm Post subject: Re: Valve adjustment every 3K? Why? |
I had a 93 Honda Del Sol with over 300k and never touched a wrench to it. They really are tough little cars. The interchangeability among the model line is as good or better than VW, you can mix and match engines easily. |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Sat Feb 04, 2023 6:23 pm Post subject: Re: Valve adjustment every 3K? Why? |
steve244 wrote: |
Hondas still have solid lifters. At least the last two I owned did. Even after they got away from timing belts.
3,000 mile intervals sounds obsessive. |
hondas don't have push rods |
steve244 Samba Member
busdaddy Samba Member
Posted: Sat Feb 04, 2023 6:41 pm Post subject: Re: Valve adjustment every 3K? Why? |
I've done over 300K on numerous Honda's, checked the valves now and then, never ever had to adjust anything. But it's apples vs: oranges comparing it to a flat air cooled engine made from economy materials, water cooled rocker on cam is completely different than pushrods and a bunch of things that expand with heat they are attached to. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Sat Feb 04, 2023 7:36 pm Post subject: Re: Valve adjustment every 3K? Why? |
If it's stock adjust them at VWs recommended service interval of 6000 miles. If modified check as often as you feel necessary for your application. VW never said adjustment was needed every 3000 miles. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Teeroy Samba Member
Posted: Sat Feb 04, 2023 7:39 pm Post subject: Re: Valve adjustment every 3K? Why? |
I check them on my Micro yearly and they seldom need to be touched even after a 8-10000 mile season. _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Teeroy Samba Member
Posted: Sat Feb 04, 2023 7:43 pm Post subject: Re: Valve adjustment every 3K? Why? |
What does Chevy suggest for milage intervals
To adjust solid lifters on their small and big blocks? Bet it's close to VW. _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
oprn Samba Member
Joined: November 13, 2016 Posts: 12741 Location: Western Canada
Posted: Sun Feb 05, 2023 8:20 am Post subject: Re: Valve adjustment every 3K? Why? |
The 36 hp engine requires valve adjustment that often because the lifters have a flat side on them that runs against a steel block in the case and they do not turn like the later lifters. As far as I know they were the only engines that require the 3K interval.
Remember them? The push rod was pressed into the lifter and you could pull them out through the heads with the rocker shafts off and change them out. Everyone that put major miles on a 36 hp engine had a bucket full of worn out lifters with their pushrods in the corner of the garage. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sun Feb 05, 2023 8:53 am Post subject: Re: Valve adjustment every 3K? Why? |
Teeroy wrote: |
If it's stock adjust them at VWs recommended service interval of 6000 miles. If modified check as often as you feel necessary for your application. VW never said adjustment was needed every 3000 miles. |
Yes they did go back to page one to see the manual references. They (VW) made the 6k change around 1971 and in a service bulletin established .006 as the setting for all models superseding early information. They did this to avoid all the confusion which is still present it seems. If you don’t run hot you’ll most likely never experience a problem in stock form. |
Bonesberg55 Samba Member
Posted: Sun Feb 05, 2023 4:14 pm Post subject: Re: Valve adjustment every 3K? Why? |
steve244 wrote: |
Bonesberg55 wrote: |
We bought a new Honda Element in 2004 & after 260,000 miles, I had never adjusted the valves. It was as quiet as the day we bought it. That's American engineering. |
Not sure you're serious...
In any case, Honda called for adjustment if necessary every 30k miles. The problem isn't noisy valve trains, but recessed seats. The valves don't close completely. No excessive noise, but the exhaust valves will burn. They need to close completely to cool.
Later Hondas still called for adjustment every 110k miles.
YMMV |
I'm serious. When valves wear, the gap widens & you hear that click & yes, the seat deepens & the valves groove but you hear that. If the valve did not completely close, you would lose compression. |
mark tucker Samba Member
Posted: Sun Feb 05, 2023 5:17 pm Post subject: Re: Valve adjustment every 3K? Why? |
it's a cheep car what do you expect? but if it's built right with the right parts preped right and the right oils it can go much much farther. but if you just build disposable vw engines like most do..adjust away. |
Posted: Sun Feb 05, 2023 5:19 pm Post subject: Re: Valve adjustment every 3K? Why? |
steve244 wrote: |
YMMV |
I meant the American engineering bit.
Exhaust valves will require loosening to make a good seal. _________________ 82 AC vanagon approx 200K miles (3K are mine).
DD is a 2015 Leaf
Road Trip to Hell (FL 2023)
The Vanagon's drivetrain and chassis restomod thread. Best sung to the tune of I Did It My Way... |
oprn Samba Member
Posted: Sun Feb 05, 2023 6:44 pm Post subject: Re: Valve adjustment every 3K? Why? |
On an air cooled VW normal wear opens the gaps with time - period! If an exhaust starts to tighten up... you are in trouble! Take the head off and replace the exhaust valves NOW! The only way they will tighten up is from the valve stem stretching under the head because it has over heated and is weak. If you just adjust it and go it will not be very long and you will be buying a head, piston and possibly other internal parts.
Other makes of engines may wear differently but that discussion is irrelevant here. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Mon Feb 06, 2023 3:28 am Post subject: Re: Valve adjustment every 3K? Why? |
it was the 1950s....what else would you be doing at the weekend other than 'tinkering' with the car? _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
oprn Samba Member
Posted: Mon Feb 06, 2023 4:34 am Post subject: Re: Valve adjustment every 3K? Why? |
Anyone that has daily driven an air cooled VW past the venerable 36 hp knows that 3000 mile interval for valve adjustment is excessive. Once the initial break in period is done they just don't change that much. Touching them up every 3rd or 4th oil change is more realistic in my experience. With the lack of quality of the modern valve cover gaskets taking them on and off every 3000 miles will have you chasing leaks perpetually! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Mon Feb 06, 2023 8:32 am Post subject: Re: Valve adjustment every 3K? Why? |
steve244 wrote: |
steve244 wrote: |
YMMV |
Exhaust valves will require loosening to make a good seal. |
Von Braun headed the Apollo project, but it was American engineering that got us to the moon. It is still amazing over 50 years later. |
Abscate Samba Member
Posted: Mon Feb 06, 2023 12:43 pm Post subject: Re: Valve adjustment every 3K? Why? |
Multi staging was a Russian design from 1946, but once you really decide there is more to the world than Olive Garden, you find thought of this in 14th century.
I’ve scoured curricula and found Engineering, but nothing called “ American Engineering”
Does that include Canada ? _________________ .ssS! |
Posted: Mon Feb 06, 2023 1:16 pm Post subject: Re: Valve adjustment every 3K? Why? |
Salad & breadsticks for me! Keep 'em comin'! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Feb 06, 2023 1:23 pm Post subject: Re: Valve adjustment every 3K? Why? |
I "think" we answered the OP's question. _________________ Glenn
Member #1009
#BlueSquare |
