markusb Samba Member
Joined: October 24, 2014 Posts: 14 Location: Ontario, Canada
Posted: Sat Feb 04, 2023 1:08 pm Post subject: Girling G60 - spare parts drying up? |
Years and years ago I converted my syncro to g60 front brakes using info at syncro.ca, from Dave Marshall, and they have been great. Saved me more than once.
I have to refresh everything since the van was sitting for a while and I had a hard time locating some parts:
276mm rotors seem to unavailable. I found that 282x25mm passat rotors seem to fit my setup. 288mm was too big unless I ground down the carrier some or had the rotors machined down, which i was not crazy about.
The brake pads are hard to come by. I did manage to locate a set. But due to the difficulty will order another set to keep on hand.
I cannot locate the glide pins ANYWHERE. If anyone has a tip here, ease let me know. I need some badly.
Just a heads up if you are going this route. There may be options with better parts availability at present. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6357 Location: Honolulu,Hawaii and France
mtnhome Samba Member
Joined: July 17, 2010 Posts: 498 Location: Summit County, CO
Posted: Sat Feb 04, 2023 4:21 pm Post subject: Re: Girling G60 - spare parts drying up? |
Parts are a little harder for find but they are out there. Burley has rebuild kits with new pistons, Rock Auto shows 276mm rotors. Slide pins seem to be non-existent but I find it hard to believe that the G60 calipers are the only one that used this slide pin. Try reaching out to Bigg Red in the UK. _________________ '84 Westy, '93 Subaru ej22 and Subarugears 5speed
Build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=763098&highlight= |
Kdj Samba Member
Joined: January 28, 2017 Posts: 142 Location: Naptown
Posted: Sat Feb 04, 2023 6:11 pm Post subject: Re: Girling G60 - spare parts drying up? |
I bought a set of rebuilt calipers from rock auto about 2 months ago. But they where listed as last pair! |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Feb 04, 2023 8:07 pm Post subject: Re: Girling G60 - spare parts drying up? |
I just finally did my conversion on my Syncro after having the parts sit on the shelf a few years.
Just jumped on Rock Auto and ordered what I needed for the future.
1991 Audi V8
Ordered front calipers left & right. SAID ONLY 1 REMAINING, but different vendors have shown 1 remaining so should be a pair left... somewhere? The pictures they had did not show the "Girling" names so feeling a bit skeptical
Rubber piston boots
Slide pin boots.
Pagid brake pads
Did not see any slide pins so that should be a warning to keep your boot seals good and pins lubricated.
2003 MB ML320
MB 303mm dia. Rotors _________________ This free advice is worth exactly what you paid for it.
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Sun Feb 05, 2023 2:02 am Post subject: Re: Girling G60 - spare parts drying up? |
If these are non floating calipers you can guide pin them with simple hardware , just drill out the caliper holes and fit flanged bolts,for example. _________________ .ssS! |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
Sodo Samba Member
Joined: July 06, 2007 Posts: 9610 Location: Western WA
Posted: Sun Feb 05, 2023 11:54 am Post subject: Re: Girling G60 - spare parts drying up? |
Dang.
But you mainly need new slide pins if they haven't been touched in 20 years....
If it's been awhile it's not a big deal to take the slide pins out, grease and reinsert?
Just an idea. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Sun Feb 05, 2023 12:11 pm Post subject: Re: Girling G60 - spare parts drying up? |
New calipers? If you have a link to that let me know. Mail order, I hate dealing w cores.
My slide pins were so rusty 2 required heroics to get out, but all 4 heads were so rusty the boot couldn't stay on them. |
Posted: Mon Feb 06, 2023 10:17 am Post subject: Re: Girling G60 - spare parts drying up? |
Ordered the pins. I'll see if it's good. |
mathieux46 Samba Member
Posted: Mon Feb 06, 2023 11:56 am Post subject: Re: Girling G60 - spare parts drying up? |
Hi,
I'm in the process of installing Smallcar front brake kit, just painted them red last night
I have installed G60 on my 2 other vans and while there is no marking of Girling 60 on the calipers supplied by Smallcar but they look identical to my eyes to G60 calipers.
Makes me wonder if this means the supply is not drying up and we need to search for another model than 1990s Audi 200 brakes caliper when searching for spare calipers.
Thanks
Mat |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Mon Feb 06, 2023 2:01 pm Post subject: Re: Girling G60 - spare parts drying up? |
It does seem like the caliper supply is drying up.
Still some rebuilt and aftermarket new ones around but I didn't find very many in stock when I just looked.
Mark |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 503 Location: Hi-top Country
Posted: Mon Feb 06, 2023 10:24 pm Post subject: Re: Girling G60 - spare parts drying up? |
Let's see..parts from a mid 80's Audi drying up? Yes, you are correct. Damn you Audi for not having a legacy program like the other German juggernauts.
If you're running G60's already then your carriers are already 'machined' for the Vanagon spindle caliper spacing so what's a little more to accommodate the 288's? _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
Posted: Tue Feb 07, 2023 5:37 am Post subject: Re: Girling G60 - spare parts drying up? |
crazyvwvanman wrote: |
Mark |
When I looked at Rock Auto's website checking out the calipers I could see no "Girling" brand names on the selection of calipers they had. Last time I had looked and bought a set every vendors rebuilt pictures you could see it clearly. _________________ This free advice is worth exactly what you paid for it.
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Tue Feb 07, 2023 1:53 pm Post subject: Re: Girling G60 - spare parts drying up? |
If you pretend you own a 1992 to 1994 Audi S4 or a 1995 to 1997 Audi S6 (I have one of each), then Google seems to show a fair number of G60 calipers available. At ECS Tuning, they are cheap and come with that important bracket needed for the conversion on your Vanagon:
https://www.ecstuning.com/b-cardone-parts/remanufactured-front-brake-caliper-right/447615124kit~car/
Note that this Audi caliper bracket does not require a spacer for fitting onto the Vanagon Syncro, but that bracket does need to be milled and the bolt holes enlarged and re-centered. I paid $60 for the milling/drilling at a machine shop. _________________ '86 Syncro Westy SVX |
Posted: Tue Feb 07, 2023 3:34 pm Post subject: Re: Girling G60 - spare parts drying up? |
If you look deeper at that link you can see that they only have RIGHT side front calipers listed.
That is what I saw when I looked previously, at that US source as well as some others.
Mark
Howesight wrote: |
https://www.ecstuning.com/b-cardone-parts/remanufa...~car/..... |
Posted: Tue Feb 07, 2023 8:37 pm Post subject: Re: Girling G60 - spare parts drying up? |
That's a good catch, Mark! Sorry to give folks false hope.
For anyone who is determined to buy these G60 calipers, most of the URS4 and URS6 owners/modifiers have upgraded from the G60 brakes to Porsche or Brembo brakes and likely have G60's gathering dust somewhere. _________________ '86 Syncro Westy SVX |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Wed Feb 08, 2023 11:54 am Post subject: Re: Girling G60 - spare parts drying up? |
I have found this link to be a useful source for part numbers:
https://forums.quattroworld.com/9080/msgs/13157.phtml
If you head over to vwvortex, you will see that the Girling G60's were a popular upgrade for a lot of different enthusiasts. So we Vanagon people are not the only ones facing this resource problem.
A web search using the OE part numbers does turn up some parts throughout the world, but sadly most are pretty expensive these days. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
valvecovergasket Samba Member
Posted: Wed Feb 08, 2023 12:02 pm Post subject: Re: Girling G60 - spare parts drying up? |
Howesight wrote: |
a tangent, but i wouldnt trust the "in stock" status at ECS any more than the "in stock" status at pelican parts, which is to say... not at all.
and i suppose that makes sense because theyre both under the ECS umbrella. _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
