Amiga0ne Samba Member
Posted: Sat Feb 04, 2023 4:50 pm Post subject: Need new starter motor |
Hi All,
I have a '63 Beetle which has been converted to 12V. It has a 12V flywheel (I believe) as I recently removed an old 200mm clutch and re-installed a new 200mm clutch in the car. I think it is the original 6V trans however as it looks like it has been grinded to fit the larger flywheel.
But it currently has what I believe is a 6V starter (Bosch U-EED 0,5/6 L34). Can I just install a 12V starter in the car and replace the bushing to suit?
This one in particular:
https://www.classicveedub.com.au/cvd_new/part_detail.aspx?parts_id=16939
Thanks for the advice! |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Feb 04, 2023 4:57 pm Post subject: Re: Need new starter motor |
If it has a 12v 200mm flywheel, you need a 12v starter. The 6v one will have a different gear pitch. It will grind like a mofo.
If you get the standard 12v non-supported starter, you also will need the 6v to 12v conversion bushing for the bellhousing.
If you get a self supporting autostick starter, you don't need a bushing. |
Posted: Sat Feb 04, 2023 5:38 pm Post subject: Re: Need new starter motor |
Pruneman99 wrote: |
Thanks Pruneman. Not sure what you're referring to in the above however. |
Posted: Sat Feb 04, 2023 5:43 pm Post subject: Re: Need new starter motor |
Amiga0ne wrote: |
Pruneman99 wrote: |
It was a different starter used in the later cars with the AutoStick transmission. It's self supported, so you don't need to mess with the stupid bushing in the bellhousing.
https://socalautoparts.com/product/starter-bug-ghia-type-3-autostick-12-volt-rebuilt/ |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Sat Feb 04, 2023 5:48 pm Post subject: Re: Need new starter motor |
Amiga0ne wrote: |
Pruneman99 wrote: |
The Autostick starters don't have the starter pinion shaft fitted into the bell housing. They "Self support" the pinion shaft.
No bushing required.
The upper starter in the image below is an auto stick starter. See the difference?
Prune, you have treed me on posts two times today.
Note to self. "Don't try to out type an ATC! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Feb 04, 2023 5:56 pm Post subject: Re: Need new starter motor |
Heh. Can you tell I'm bored? My only day off this week,.and I somehow got roped into babysitting some doggies. Oh well, I needed a do nothing day to unwind anyway. Work has been insane. |
Posted: Sat Feb 04, 2023 6:04 pm Post subject: Re: Need new starter motor |
Pruneman99 wrote: |
Dogs are fun!
Take um for a walk and enjoy a little fresh air, while your at it. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sun Feb 05, 2023 7:55 am Post subject: Re: Need new starter motor |
That's the bushing you'll need. If the engine is out, it's easy to change. If you are doing it with the engine in, it's a bit harder. Most people us a tap that will "screw into" the old bushing with enough bite to pull it out. |
Dusty1 Samba Member
Posted: Sun Feb 05, 2023 9:15 am Post subject: Re: Need new starter motor |
Pruneman99 wrote: |
Amiga0ne wrote: |
Pruneman99 wrote: |
The self- supporting starter is the Bosch SR17X. As stated above they came in vehicles with automatics and auto- sticks as well as being the go- to starter in many Things.
I've never bought a new one. Don't need to. Still have a few removed from autostick vehicles decades ago.
Why screw around with a bushing if you don't have to?
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Feb 12, 2023 5:15 am Post subject: Re: Need new starter motor |
Did you look at the "compatible vehicles" list ? Do you have a Jetta or an EOS? |
