pharos Samba Member
Posted: Sun Feb 05, 2023 5:07 am Post subject: Fitting 70's IRS gearbox to 67 Split Bus. |
Hi,
I bought a Splitscreen Bus IRS Conversion Kit - With Standard Spring Plates (Using Beetle Setup)
https://www.coolairvw.co.uk/product/irsbeetle/
Everything goes well except the nose cone missalliming with shifting rod. The IRS gearbox is higher about 1.6 inch.
I think that I need to change the beetle Nose Cone to get it centered. Can you advice which Nose cone to use?
_________________ http://www.facebook.com/groups/vwbug/ |
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
charles henson Samba Member
Posted: Sun Feb 05, 2023 3:02 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
I used the nose cone off my splitscreen gear box and the hockey stick for a A-H single side plate gear box out of a L bug 73/74? model.
I bought a new gasket for nose cone to put on the gear box before fitting.
cheers |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2830 Location: West Palm Beach, FL
Posted: Sun Feb 05, 2023 4:53 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
I was already under my bus working on my shift rod coupler and took this pic for you.
My swing axle transmission has nose cone: 211301311G
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Posted: Sun Feb 05, 2023 5:07 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
Using this transmission front mount 211301265
pharos Samba Member
Posted: Sun Feb 05, 2023 5:14 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
don.ville wrote: |
Thanks, I'll try to find this Nose cone part _________________ http://www.facebook.com/groups/vwbug/ |
dtadpole Samba Member
Joined: November 15, 2012 Posts: 85 Location: Southern Illinois
Posted: Mon Feb 06, 2023 8:32 am Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
I haven't completed my irs conversion I am using a different method but I changed out my beetle nose cone to the split cone and hockey stick Noted in my directions. I think either stick will work but need the bus cone. _________________ 1965 velvet green walk-thru standard
scrappythebus.com
https://youtube.com/@dtadpole |
pharos Samba Member
Posted: Mon Feb 06, 2023 1:59 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
dtadpole wrote: |
I haven't completed my irs conversion I am using a different method but I changed out my beetle nose cone to the split cone and hockey stick Noted in my directions. I think either stick will work but need the bus cone. |
As long as you have the beetle cone and the split one, Do you mind to measure both for me. In my case the beetle transmission nose cone needs to be dropped about 1.5" to be centered. _________________ http://www.facebook.com/groups/vwbug/ |
Posted: Tue Feb 07, 2023 7:15 am Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
When I get home late this evening ill try to measure the differences. _________________ 1965 velvet green walk-thru standard
scrappythebus.com
pharos Samba Member
Posted: Tue Feb 07, 2023 12:52 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
dtadpole wrote: |
When I get home late this evening ill try to measure the differences. |
Thanks, waiting for your input _________________ http://www.facebook.com/groups/vwbug/ |
demo four Samba Member
Joined: January 12, 2011 Posts: 46 Location: the garage
Posted: Tue Feb 07, 2023 2:22 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
charles henson wrote: |
cheers |
I used an AM gearbox for my last bus IRS conversion and swapped the nosecone from my split gearbox and used that and everything fitted up and worked great.
You need to swap the nosecone and hockey stick to the beetle box. |
snuffelupabus Samba Member
Joined: October 03, 2006 Posts: 63 Location: St. Johns, Newfoundland, Canada
Posted: Tue Feb 07, 2023 7:29 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
Beetle IRS box with Split bus nose cone and hockey stick
Posted: Wed Feb 08, 2023 6:45 am Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
Beautiful trans there snuffalbus!
Here is the pics with the tape measure on each nose cone I don't know how much it will help since now I realize the measurement is from the bottom of the mount on each nosecone but maybee!
beetle nosecone
Bus nosecone
scrappythebus.com
pharos Samba Member
Posted: Wed Feb 08, 2023 1:35 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
dtadpole wrote: |
Beautiful trans there snuffalbus! |
Thank you. Appreciate _________________ http://www.facebook.com/groups/vwbug/ |
Daddybus Samba Member
Posted: Thu Feb 09, 2023 12:56 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
The bus nose cone and hockey stick are different than a Type 1. The holes of the nose cone mount are a different height (211 part number). The indent for the shift coupler set screw is on the top side of a Type 1 hockey stick and on the bottom side of a Type 2 hockey stick. Rancho Performance Transmission carries an aftermarket bus nose cone, which has the hole to mount a reverse light switch. They also have the hockey stick, which comes stock or welded and reinforced. The nose cone mount is the same Type 1 and Type 2, but the Type 2 is stiffer. The lack of reduction gear boxes when running IRS or beetle swing axle puts more stress on the front mount. A bus front mount (211 number) and a mid-mount is the way to go. The Daddybus runs a Type 1 IRS and I have broken...1 Type 1 rubber mount, one urethane mount, and a bus mount. I haven't broken a mount since I went with the Wolfgang mid-mount (no drilling required). |
Posted: Thu Feb 09, 2023 2:20 pm Post subject: Re: Fitting 70's IRS gearbox to 67 Split Bus. |
Thanks Daddybus for the information I am def. going to go with a mid mount seems like a great addition!! _________________ 1965 velvet green walk-thru standard
scrappythebus.com
