tuxy2001 Samba Member
Posted: Tue Feb 07, 2023 12:23 am Post subject: Clutch pedal and cable |
So I was mucking around with the pedal adjustment on my bug and the clutch pedal fell all the way to the floor meaning the cable came of the hook. After some fiddling I got the cable back on the hook and bolted everything up andddd the clutch doesn’t work now. I start the car but when I push the clutch pedal In I can’t shift into gear, any ideas??? |
BMFBMF Samba Member
Joined: November 13, 2020 Posts: 356 Location: Swtzerland
Posted: Tue Feb 07, 2023 2:00 am Post subject: Re: Clutch pedal and cable |
If someone pushes down the pedal do you see the other end move? If yes cable is connected and you might just need to do a clutch freeplay adjustment. _________________ -----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Tue Feb 07, 2023 7:21 am Post subject: Re: Clutch pedal and cable |
BMFBMF wrote: |
If someone pushes down the pedal do you see the other end move? If yes cable is connected and you might just need to do a clutch freeplay adjustment. |
This.
And could be broken clutch hook, broken clutch pedal, stretched cable.......
I'd take a look myself but I'm in Arizona USA and don't fly..... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Feb 07, 2023 11:52 pm Post subject: Re: Clutch pedal and cable |
BMFBMF wrote: |
I just tested and yes it does move so it must just need adjusting. I don’t see how it coming of the hook and being reinstalled straight away means it needs adjusting tho |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed Feb 08, 2023 12:10 am Post subject: Re: Clutch pedal and cable |
Check that the Bowden tube is installed correctly. Maybe with all the slack out, it got out of position and affected your clutch adjustment a bunch? It has to slide into the tunnel fitting a little. |
BMFBMF Samba Member
Posted: Wed Feb 08, 2023 9:20 am Post subject: Re: Clutch pedal and cable |
pedal adjustment = things change. _________________ -----Slava Ukraini-----
vwoldbug Samba Member
Posted: Thu Feb 09, 2023 9:18 pm Post subject: Re: Clutch pedal and cable |
Were you doing anything to the pedal stop on the floor. |
