Alexzeat Samba Member
Joined: February 27, 2022 Posts: 37 Location: Lanzarote - Spain
Posted: Wed Feb 08, 2023 6:53 am Post subject: Start engine problem |
Hello to all
I have a problem with my engine, when i try to start in the early morning( cold) it start very very fast, then i use the bus and stop the engine, try to turn on again and it start very very fast. BUT if i stop the engine and wait 15 minutes and then try to start again, it take time and seems like one cilinder no work.... later if i make more gas , it dissapear... but i dont know what is the problem.
Please check the video atached;
_________________ Volkswagen T1 Kombi 1500 1963
Volkswagen T2 Pickup 1600 1974 |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Wed Feb 08, 2023 1:34 pm Post subject: Re: Start engine problem |
This is normal.
First start, engine is cold, choke is on, throttle is held open by choke mechanism. Engine idles fast.
Second start, engine is warmer, choke on less, throttle is held open less - engine still idles fast, it has warmed so spins easier with less throttle.
Later start - engine is hot, choke cools down and closes, mixture is now too rich for hot engine, engine harder to start. When it starts it idles at correct speed, 850 RPM +/-
You need two different starting approaches :
Cold engine start - one press of gas pedal, release, crank, starts quickly.
Hot engine start - press and hold gas pedal, crank and wait for air to pump into the engine to lean out the mixture, engine starts.
This happens because the engine holds heat for longer than the choke mechanism when you stop the engine. _________________ Ancient vehicles and vessels
Posted: Wed Feb 08, 2023 2:38 pm Post subject: Re: Start engine problem |
If the float needle valve doesn't seal 100% that can cause this as well. Check to see if your dipstick smells of gasoline. |
Posted: Wed Feb 08, 2023 2:44 pm Post subject: Re: Start engine problem |
Wildthings wrote: |
The dipstick of oil? _________________ Volkswagen T1 Kombi 1500 1963
Posted: Wed Feb 08, 2023 4:56 pm Post subject: Re: Start engine problem |
Yes, if you are leaking gas past the needle valve when the engine isn't running it may well show up in the crankcase. A sniff test isn't super definitive, but is a good place to start. |
Posted: Thu Feb 09, 2023 12:00 am Post subject: Re: Start engine problem |
Wildthings wrote: |
ok thanks , supposedly it smell gas , what i need to do? _________________ Volkswagen T1 Kombi 1500 1963
Posted: Thu Feb 09, 2023 3:59 am Post subject: Re: Start engine problem |
Alexzeat wrote: |
Wildthings wrote: |
ok thanks , supposedly it smell gas , what i need to do? |
Test to make sure the needle valve seals well and/or adjust the float. |
Posted: Thu Feb 09, 2023 5:25 am Post subject: Re: Start engine problem |
Wildthings wrote: |
Alexzeat wrote: |
Wildthings wrote: |
I tried this morning, and it smell gas....
Do you know a tutorial to solve it?
Thank _________________ Volkswagen T1 Kombi 1500 1963
