Twizzstyle Samba Member
Posted: Tue Jul 06, 2004 11:13 pm Post subject: KYB shocks... GR-2 or Gas-A-Just? |
I'm new to this forum (and Volkswagens for that matter)...
I got a manx clone dune buggy as a gift from my grandpa, and I'm doing a bit of work on it. (I'm a Subaru nut originally, now VW's have taken me over too! )
Anyways, I want to get some new shocks for it. I don't want to spend a fortune, but I want something that is going to handle very well. This is mostly going to be a street driven car.
So I just need to decide between the GR-2's and the Gas-A-Just. It sounds like the Gas-A-Just's are stiffer, is that right? Those would be the ones I want in that case.
Also, my buggy has what looks like the "Select-A-Drop" adjuster on the front beam (The pan is a 1961 bug, so it is link pin). I haven't really had a chance to look at it, but when I changed a bolt on the bottom, it didn't raise or lower the car, but changed the stiffness of the front suspension. Is there something to adjust on the top as well? Anybody have a "Select-A-Drop" and can explain to me what it does exactly? I would like to lower the buggy just a tad (inch or so).
Thanks for any help! I've really fallen in love with this car and how easy it is to work on!
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Sat Jul 10, 2004 5:11 am Post subject: |
I've run GR2 for the past 15 years. With a light fiberglass body the GR2 will more than firm enough. _________________ Glenn
Member #1009
#BlueSquare |
workingstiff Samba Member
Posted: Mon Jul 12, 2004 8:51 am Post subject: |
I would agree, I use the gas-adjusts for my rail (off road)for years also. When I'm ready I'm getting GR2's for my buggy. |
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Mon Jul 26, 2004 7:29 pm Post subject: |
I put GR-2's on the front and Gas Adjust on the rears. Worked good for me - CD's don't skip. |
zerodog Samba Member
Posted: Tue Aug 03, 2004 10:24 am Post subject: |
Gas adjusts suck. I run them on my baja. They have no rebound dampening and to much low speed dampening. They buck over every pot hole and manhole cover in the road. I am spending the money and buying bilsteins for mine. But I go offroading. For street use you want it to be soft. I would spend more than the $20 or $30 bucks for the KYs and get some good car shocks. Like gabriel or monroes. I will never by the KYBs again. Anyone who likes these shocks doesn't know what good suspension should feel like. |
